Civil 3D Forum
Rotate Viewport?
20 REPLIES 20
Message 1 of 21
jennifera
2279 Views, 20 Replies
Rotate Viewport?
I know this must seem elementary to AutoCAD users more experienced than I, but how do you rotate a view??
I have a subject location in my model space facing north, but I want it to rotate ninety degrees to face east in my paper space. I have received drawings from other users utilizing this method, but no one has ever told me how to accomplish this task.
Please help me out... my boss is making me crazy with changing appearances of my workspace!
Thanks in advance to anyone who is reading this thread - I greatly appreciate it! Jennifer Acevedo, EIT
20 REPLIES 20
Message 2 of 21
tcorey
in reply to: jennifera
2010: Be sure VPROTATEASSOC is set to 1 and you can just rotate the viewport. The view within the viewport will rotate as well.
2009 and older: Go to modelspace on your layout. Use Dview command, TWist option to rotate the view within the viewport. Rotating the viewport object will not rotate the view in old versions.
Tim Corey
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 21
jennifera
Still on 2009. I tried out your suggestion Tim and my subject does rotate in my model space, but does not rotate in paper space. I want to still be able to work with my subject as it is (facing north), but in paper space, I want my subject to face east. The Dview command did not rotate my view in paper space.
Any other suggestions? greatly appreciated ~ he is making my life a living .... thanks!
Message 4 of 21
You need to be in the viewport in order for the DVIEW Twist to work. It is
a per viewport command.
Brad
C3D 2010 on Vista Business 64 SP 2
LT 2010 on XP Pro SP 3
wrote in message news:6225758@discussion.autodesk.com...
paper space.
.... thanks!
Message 5 of 21
I think you can also do this in MS, save a View and restore the View in the
PS layouts.
John
"Brad" wrote in message
news:6225740@discussion.autodesk.com...
Brad
paper space.
.... thanks!
Message 6 of 21
jennifera
The Dview command does not work in paper space on ACAD 2009. When you prompt Dview at the command line, it states that you must be in model space to use this command. So there goes the theory of using this command in the viewport.... As for right clicking on the actual viewport while in paper space, 2009 gives you the option to rotate the viewport, but it will only rotate the viewport itself, not the subject in model space. Also when you call up the properties for the viewport, there is not option to rotate the viewport. Someboy out there must know how to do this....
this is beginning to get frustrating. I also looked in the Help on ACAD 2009 ~ unfortunately it was not any help at all. Nothing in there about rotating your subject in paper space view.
I do not want to get anyone upset, but I am sure you can sympathize with my frustration - you have all had it on one occasion or another.
Anything else I can try?
Message 7 of 21
In paperspace double-click inside a viewport. This will put you in
Modelspace inside the PS Viewport. Now use Dview twist.
"jennifera" wrote in message news:6225778@discussion.autodesk.com...
Message 8 of 21
The method I use:
double-click viewport (model space) >
MVSETUP > ALIGN > ROTATE VIEW > enter rotation angle. Done.
Message 9 of 21
tcorey
Hello Jennifer,
I think you might be confusing ModelSpace with Model Tab. Here's a recipe to do what you want:
1. From the command prompt, type TILEMODE and set it to 0.
2. Now you are on a layout tab, in PaperSpace.
3. Pick the viewport object, right click, select Properties. See the option Display Locked? Be sure it is set to No.
4. From the command prompt, type Mspace. Note that your crosshairs only work within the limits of the viewport? You are in modelspace, buy on a layout tab, different from being in modelspace on the model tab.
5. Type Dview and Enter. When prompted to select objects or DView Block, pick any object from the drawing. When it asks for CAmera, Target, etc., type TW for Twist. When prompted for an angle, type -90. This will make North face to the right of the screen.
6. Press enter and you're back at the command prompt with your view rotate 90 to the right within your viewport.
This will not affect the views in other viewports or on the model tab.
Best regards,
Tim Corey
Tim Corey
Redding, CA
Message 10 of 21
I use DVH (attached)
Message 11 of 21
Not to fan the flames of Dview -vs- UCS but I'm with John and saving the
view in MS; and a handi by-product of that is if you're inclined to use SSM
you can drag and drop that view into any drawing in the set.
I use UCS > 3point. Zoom>> Center >>> scale
and save the view
Joe
Message 12 of 21
Ohh, now you 've done it. 😉
John Mayo, PE
Core i7 920 6GB DDR3
Radeon 4870HD 1 GB
Vista64
Message 13 of 21
I won't fan the flames either, because that could cause a small discussion
group riot (I've seen them before.) With that being said, I have recorded
the method that I use, and this has worked for me for years. DVIEW twist
would do the same thing, essentially. Note that the viewport was activated
by double-clicking inside it, and the viewport was unlocked. You can view
the process at http://screencast.com/t/f8pz7itHkS7
Jason Hickey
http://beingcivil.typepad.com
"Joe Bouza" wrote in message
news:6226003@discussion.autodesk.com...
and save the view
Joe
Message 14 of 21
wlewis
wow - that's the cool thing about cad... a few different ways to do a simple task. I'll have to try those options one of these days..
my simple way is to change the plan view in model space and then create a new layout tab. the new viewport will be in the current plan setting.
like Joe has explained but add "Plan" to the command then saving the view.....
>saving the view in MS;
ucs --> ob --> select the feature to align --> plan 'current ucs'.
select layout tab and then mview... there it is. adjust scale accordingly. Edited by: wlewis on Jul 28, 2009 2:07 PM
Message 15 of 21
That's it exactly
Joe
Message 16 of 21
ACADuser
ALIGNSPACE
The easiest and quickest way to accurately scale and align a viewport in paperspace to a properly drawn viewport boundary in modelspace.
ACADuser
Civil 3D 2018, Raster Design 2018
Windows 7 Enterprise
Dell Precision 5810 Workstation
Intel Xeon E5-1630 v3 @ 3.70GHz
32GB RAM, NVIDIA Quadro K2200 4 GB GDDR5
DUAL 27" Dell UltraSharp U2713HM
Message 17 of 21
ACADuser
> have a subject location in my model space facing north, but I want it to rotate ninety degrees to face east in my paper space. I have received drawings from other users utilizing this method, but no one has ever told me how to accomplish this task.>
Are the "other users" your co-workers ? Why not ask them to show you.....
ACADuser
Message 18 of 21
jennifera
Thank you very much Jeff! I did not get to try out your suggestion until this morning and it works.
Thank also to everyone else who has been watching this thread - you have all been very helpful.
Message 19 of 21
jennifera
No, the "other users" were not co-workers of mine. The work I have seen this method used in was in files we received from other companies and past sub-consultants. So, unfortunately, I was not in a position to ask these other users how to accomplish this.
Message 20 of 21
Place this in a button.
^C^CUCS;n;OB;\plan;c;
Here's one to get back to World.
^C^Cucs;w;plan;w;
John Mayo, PE
Radeon 4870HD 1 GB
Vista64
Rail Community
