Civil 3D Forum
Rotate station 180 degree
4 REPLIES 4
PPG9999
2074 Views, 4 Replies
Hi Everyone,
I'm using Civil 3D 2010 and would like to know how can I rotate station number 180 degree from the original? I did move the stations to the other side but I couldn't rotate the station number. For example, I move the station from right side to the left side and station numbers look upside down. I tried to change on Edit Alignment Label under rotation from 0 to 180, but it still didn't change. Please help!! Thanks in advance.
Polly
4 REPLIES 4
rhdins
in reply to: PPG9999
Do you want to rotate all of them, or just one station? You need to change the station rotation in your station label style.
Right click on your alignment and select "edit alignment labels" then "edit current selection" once you've selected the style you want to edit, then under the "Layout" tab change the rotation angle to what you want.
Hidden_Brain
turn "PLAN READABILITY" to false under the GENERAL tab in your station label style
PPG9999
Thank you youngEIT. It works now. That is the trick. If you don't do that it won't work. Thanks everyone.
Now it's 5 years later and your answer helped immensely.
Rail Community
