So your saying that if I import my points from a .txt file I am not ablt to rotate or modify the location of the points? And that you can only rotate points that you have created in AutoCAD?
I am having to go back to LDD2004 to rotate my points, when I find that I need to roate them to a recorded Plat information. I really am not a fan of having to do that but until I can find a better way thats how I need to do it, I have tried searching for an update point tab or check box or setting with no luck. Not sure why they wouldn't wnat you to be able to modify point locations in such a mannor.
Nate S
If you imported the survey points using an import event in the survey database you can right click on the survey database and transform the database.
Points imported from text files directly into your drawing are editable using the generic editing commands (move, rotate, etc.). Points inserted from a survey database must be manipulated with the survey tools since they need to maintain synchronization with the database.
