hakangus
Message 1 of 19 (495 Views)
Rotate multiple points along alignment
495 Views, 18 Replies
01-14-2014 12:47 AM
Some years ago there was a VB script called Rotate Points.dvb that rotated multiple Civil Points along an alignment. Anyone have a similar command working for Civil R2013?
Ok, my test drawing never allowed one of the conditional branches to be hit, and it happened to have 2 parenthesis  that shouldn't have been there. This version should work for you.
Product Support
AlmasSuljevic
Message 2 of 19 (447 Views)
Re: Rotate multiple points along alignment
01-15-2014 06:34 AM in reply to: hakangus
Hi hakangus,
I am not aware of that script, but you may be able to rotate points with similar procedure to rotate points independently of point label, as described in the blog post Seth Hall wrote. Here is the link: http://beingcivil.typepad.com/my_weblog/2010/01/rotate-point-marker-independently-of-the-point-label...
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
hakangus
Message 3 of 19 (444 Views)
01-15-2014 07:08 AM in reply to: hakangus
Thank you for taking your time.
I´m afraid that it didn´t help me.
On my Alignment I put Points with the command Point/Measure Alignment and took the elevations from my profile.
All points were labeled with a +-sign and elevation and were rotated 0 degrees.
What the script made for me in those days was the following:
I selected the Point Group, choose the Alignment and the script rotated the points perpendicular to the Alignment for every point.
It saved a lot of time instead of rotating each point individually.
It was meantioned in an older forum thread but I can´t find the actual script anymore. (Rotate point.dvb)
mathewk
Message 4 of 19 (417 Views)
01-16-2014 10:39 PM in reply to: hakangus
I wrote that app. It has not been updated to 2013 or 2014 unless some else has done it.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Jeff_M
Message 5 of 19 (412 Views)
01-16-2014 11:08 PM in reply to: mathewk
Matt, would you mind sharing the code for that? I could out it into a lisp or .NET dll and post back here.
Oops! Looks like I found the dvb in my archives. Stay tuned!
hakangus
Message 6 of 19 (401 Views)
01-17-2014 01:44 AM in reply to: mathewk
Cudos x 1000!
Nice to "meet" you Matt, the maker of a wonderful script!
It´s superb news if you, Jeff, would be so nice to rewrite it for me/us!
You guys made my day!
Jeff_M
Message 7 of 19 (377 Views)
01-17-2014 11:10 AM in reply to: hakangus
Attached is a new lisp for this. Command name is "ptsalign". Not sure if it functions exactly like the DVB, although it should as I used the same parameters for the rotation. I did add the LabelRotation to match the Point Rotation...this property didn't exist when the DVB was written...not sure if this is desired behavior.
Removed this lisp. Updating to match Matt's 2012 version.
mathewk
Message 8 of 19 (374 Views)
01-17-2014 11:16 AM in reply to: Jeff_M
Here is the code.  It was last updated to work with 2012.  Rename and remove the txt, change to dvb.  My code rotates blocks as well.
Matt Kolberg
Jeff_M
Message 9 of 19 (365 Views)
01-17-2014 11:45 AM in reply to: mathewk
Thanks Matt!
Jeff_M
Message 10 of 19 (358 Views)
01-17-2014 12:36 PM in reply to: hakangus
New lisp setup to function as Matt's VBA macro does. Note that this should work in all versions of C3D, 2012 and newer.
