Some years ago there was a VB script called Rotate Points.dvb that rotated multiple Civil Points along an alignment. Anyone have a similar command working for Civil R2013?
Solved by Jeff_M. Go to Solution.
Hi hakangus,
I am not aware of that script, but you may be able to rotate points with similar procedure to rotate points independently of point label, as described in the blog post Seth Hall wrote. Here is the link: http://beingcivil.typepad.com/my_weblog/2010/01/rotate-point-marker-independently-of-the-point-label...
Thank you for taking your time.
I´m afraid that it didn´t help me.
On my Alignment I put Points with the command Point/Measure Alignment and took the elevations from my profile.
All points were labeled with a +-sign and elevation and were rotated 0 degrees.
What the script made for me in those days was the following:
I selected the Point Group, choose the Alignment and the script rotated the points perpendicular to the Alignment for every point.
It saved a lot of time instead of rotating each point individually.
It was meantioned in an older forum thread but I can´t find the actual script anymore. (Rotate point.dvb)
@mathewkol wrote:
I wrote that app. It has not been updated to 2013 or 2014 unless some else has done it.
Cudos x 1000!
Nice to "meet" you Matt, the maker of a wonderful script!
It´s superb news if you, Jeff, would be so nice to rewrite it for me/us!
You guys made my day!
Attached is a new lisp for this. Command name is "ptsalign". Not sure if it functions exactly like the DVB, although it should as I used the same parameters for the rotation. I did add the LabelRotation to match the Point Rotation...this property didn't exist when the DVB was written...not sure if this is desired behavior.
Removed this lisp. Updating to match Matt's 2012 version.
Here is the code. It was last updated to work with 2012. Rename and remove the txt, change to dvb. My code rotates blocks as well.
Well, shoot, it's working in all cases I've tested. I did find a few types and misplaced variables (oops) but none that should've affected how it edits the points. Attched is a new version with those items corrected. The Clockwise, cOunterclockwise or No rotation is just how the points are oriented to the alignment. No means no roation will be applied so they will come in parallel to the alignment. Clockwise means they rotate 90 degrees right, cOunterclockwise means 90 degrees left. Input the Capitalized letter for the shortcut rather than typing the whole thing. (N, C, or O).
If this still errors, is there anything else in the command history that may point to the source of the error? Are any of the points or layers locked?
This is what I see in my CAD text window:
Command:
PTSALIGN
Select points:
Select objects: 1 found
Select objects: 1 found, 2 total
Select objects:
Select alignment:
Select objects:
Maximum offset from alignment: 1
...rotate Clockwise, cOunterclockwise, No extra rotation [No]...: n
; error: bad function: 3.14159
Command:
Ok, my test drawing never allowed one of the conditional branches to be hit, and it happened to have 2 parenthesis that shouldn't have been there. This version should work for you.
Back at work and TaDa (Trumpets and Drums)!
It´s working! I´m so happy!
A big Thank You to you guys for helping me out here!
I know this is a really old post, but hoping someone can help. i loaded the lisp and it works great, but.... I have an alignment running west to east. All of the points south of my alignment rotated great, but every point north of the alignment was upside down. i know next to nothing about LISP files, so dont know if there's something I can change to make none of my points flip upside down. Or if I'm even running this command correctly. Im running C3D 2015, so there may even be an updated command that I am not aware of???
