Valued Mentor
Valued Mentor
sjg
Message 11 of 17 (943 Views)
Re: Rotate drawing in viewport
12-06-2012 12:39 PM in reply to: rvandever21
I use ALIGNSPACE, which is also in the express tools, in the Layout Section. Very easy to use.
Steve Goessling
Land Consultants
Civil3D 2013
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
Joe-Bouza
Message 12 of 17 (934 Views)
12-06-2012 01:32 PM in reply to: LeafRiders
LOL
Lets start a UCS rebellion!:smileysurprised:
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
mathewk
Message 13 of 17 (934 Views)
12-06-2012 01:33 PM in reply to: rvandever21
Another option is to just rotate the viewport. It's super easy. The view will be rotated. The viewport will appear to be rotated, but it's not, it's clipped. You can remove the clip after if you wish. VPROTATEASSOC setting is used when rotating viewports.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
mikeevans
Message 14 of 17 (916 Views)
12-06-2012 04:21 PM in reply to: mathewk
Matt, they could try the rotate command too (grin)
Mike Evans
Civil3D 2013 / 2014 British UK
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
bvandamm
Message 15 of 17 (896 Views)
12-07-2012 04:17 AM in reply to: rvandever21
Also make sure your viewport isn't locked.
"The source of expertise is not in the memorization
of the minute details of a subject but in the thorough
understanding of the fundamental concepts on
which it is based." - Dan Appleman
doni49
Message 16 of 17 (864 Views)
01-04-2013 08:59 AM in reply to: rvandever21
This is a lisp routine that I use to DVIEW rotate my modelspace work.  It makes it so much easier.  Assuming you're alignment is one tangent, you'd pick one end then the other end.
That will be made horizontal to your viewport.
(defun dtr (x)(* pi (/ x 180.0)))
(defun rtd (x) (* x (/ 180.0 pi)))
(defun c:dvtwist()
  (setq pt1(getpoint "Select the first point:  "))
  (setq pt2(getpoint "Select the second point:  " pt1))
  (setq ang(angle pt1 pt2))
  (command "Dview" "" "tw" (- 0 (rtd ang)) "")
  (setvar "snapang" ang)
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Forum links:
AutoCAD 2013/2014/2015
AutoCAD 2010/2011/2012
AutoLISP, VB and other AutoCAD customization
Civil 3D General
Civil 3d Customization
Other Helpful links:
My File is too large to post or I can't post it due to privacy issues!
troma
Message 17 of 17 (862 Views)
01-04-2013 09:57 AM in reply to: doni49
Here is a lisp someone else posted elsewhere on the forums.
Like the last one, it sets the DVIEW TWIST and the SNAPANG  so that your crosshairs & ortho work horizontally to the screen.
This one lets you pick two points, or select a line, block, or text to use the rotation from.
Credit where credit is due! Give kudos or accept as solution whenever you can.
