rvandever21
Message 1 of 17 (5,061 Views)
Rotate drawing in viewport
5061 Views, 16 Replies
12-05-2012 09:54 AM
How do I rotate the drawing in viewport?
I want to have my profile and alignment to be in the same orientation on paper space. I have VPROTATEASSOC set to 1. I am not sure if I am using UCS and MVSETUP correctly.  All information will work.
Thank you,
Rochelle Vandever
tcorey
Message 2 of 17 (5,060 Views)
Re: Rotate drawing in viewport
12-05-2012 09:56 AM in reply to: rvandever21
Use two viewports. In the profile viewport, no rotation at all. In the alignment viewport, use Dview with Twist option.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
rvandever21
Message 3 of 17 (5,055 Views)
12-05-2012 10:11 AM in reply to: tcorey
I tried to use the DVIEW on my viewport. It says I could only use dview in model space.
tcorey
Message 4 of 17 (5,050 Views)
12-05-2012 10:16 AM in reply to: rvandever21
If you double click inside the alignment's viewport, you will be in modelspace (not to be confused with the Model tab.) Use Dview from there.
Tim Corey, Owner
Redding, CA
rvandever21
Message 5 of 17 (5,043 Views)
12-05-2012 10:44 AM in reply to: tcorey
I was able to rotate the drawing but I can scale or move the drawing to line up the profile. Is there a way to keep the rotate but turn off dview?
troma
Message 6 of 17 (5,033 Views)
12-05-2012 11:21 AM in reply to: rvandever21
When you get the rotation right, set the scale of the viewport.  Then lock the viewport to prevent accidentally changing the scale later.  Both the scale and the lock can be found at the bottom right of your main screen, or in the properties pallette.
Once you've done that you can move the viewport around in paper space, and stretch it bigger or smaller as necessary.
Credit where credit is due! Give kudos or accept as solution whenever you can.
troma
Message 7 of 17 (5,031 Views)
12-05-2012 11:22 AM in reply to: rvandever21
I just re-read your question; do you need to hit enter one more time to exit out of the dview command?
rvandever21
Message 8 of 17 (5,028 Views)
12-05-2012 11:30 AM in reply to: troma
I still have the dview command on but when I escape to move the drawing.  The alignment will change back to the original drawing.
troma
Message 9 of 17 (5,016 Views)
12-05-2012 11:52 AM in reply to: rvandever21
Don't hit Escape
Hit Enter instead.
LeafRiders
Message 10 of 17 (4,978 Views)
12-06-2012 11:55 AM in reply to: troma
This is a pretty painful solution...
Use UCS (enter) 3 (enter) click two points (left to right), this will be come your new West to East (left to right).
Final step.... Type PLAN (enter) (enter)... Proceed to set the scale of your viewport and then lock it as suggested. Good Luck!
