Civil 3D Forum
Rotate and Mirror
10 REPLIES 10
Message 1 of 11
allywhite666
2005 Views, 10 Replies
Rotate and Mirror
Is there any way to rotate and mirror an objcet while leaving the original.
eg. I have half a window like so
            A _____________
                                    | B
I want to mirror along point A and B so the bottom and left side of the window is shown.
10 REPLIES 10
Message 2 of 11
neilyj666
in reply to: allywhite666
Use the MIRROR command. .....and retain original objects
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 3 of 11
Pointdump
AW,
I don't think you can do this in one move. Copy, then rotate, looks like the best option.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 4 of 11
Joe-Bouza
in reply to: Pointdump
Express>> copy move rotate does all in one command line sequence. If I recall correctly
http://www.adris.co.uk/architectural-tips-tricks/94-issue-001-movecopyrotate-mocoro
Your Name
Your Name
Message 5 of 11
Pointdump
in reply to: Joe-Bouza
Joe,
I learn something everyday. That MOveCOpyROtate command is brilliant! Good link, too. Thank you.
Dave
Dave Stoll
Las Vegas, Nevada
Message 6 of 11
Joe-Bouza
Hi Dave
I'm sure you are aware of the contextual right click menu containing the fundemental geometric modifying command while hot gripped.They are all there
Your Name
Your Name
Message 7 of 11
Neilw_05
I didn't know about this Express tool. Nice solution.
You should also look at the Transform command which allows you do similar.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 8 of 11
Neilw_05
in reply to: Neilw_05
Actually I think the Align command is more appropriate than Transform. If you pick the destination points in reverse of the source points it will mirror.
Screen recording: http://screencast.com/t/oSfGmoyjGYTA
WIN 10 64 PRO
Message 9 of 11
allywhite666
Thank you all so much for your help.
The Align command is great, the only problem is that it dosen't leave the original line(s) behind so I have to copy with base point and paste on top of original line(s) or somewhere near and then perform the align.
I don't know where I'd be without you guys. Heart
Message 10 of 11
Neilw_05
Oops, once again I didn't read the post carefully. Obviously Align is not a solution.
WIN 10 64 PRO
Message 11 of 11
allywhite666
But is very close to what I wanted, so thank you. I think this is as close as I will get.
Rail Community
