Civil 3D Forum
RockSurf
13 REPLIES 13
Message 1 of 14
725 Views, 13 Replies
RockSurf
We are multidiscipline company
Civil/Geotech/Environmental/etc
and here is the fairly frequent
requirement we have with
regard to Rock Surface/Contours
(but I can envision very similar
application/benefit for creating
pollutions surface/contours or
anything else).
We get existing surface data
from surveyors. This is always
detailed.
Then our Geotech/Environmental
people go to the site and collect
boring/environmental logs. The
number of logs may very between
say 30 (more often) to 150 or more.
In certain cases the geotech people
look to encounter rock and they
collect rock depths/elevations.
(The environmental people collect
PID values, etc).
So we have very detailed existing
surface and only 30+ points to represent
rock depth. Often, the geotech people
want to see estimated/rough rock surface
and contours. Now, 30+ points is too
few points, I'd say, even for approximate
surface.
Is there a way, or can it be built in the
future release of Civil3D, to automatically
(not manually) generate multiple interpolated
points based on 30+ known points and
accounting for existing surface - see attached
figure.
Strah @ Langan
13 REPLIES 13
Message 2 of 14
Disclaimer: I know NOTHING about Civil3d, I am just here lurking, learning
what I can about the product.
However, with LDD you may be able to achieve your goal:
1) Make a terrain surface representing the Top of Ground elevations (a point
in the terrain may be at MSL, e.g. 5280)
2) Make an LDD terrain surface representing Bore hole depths (a point would
be a positive depth, e.g., +10).
3) Run a composite volume with a stratum for MSL vs. DEPTH, and LDD creates
a composite surface. This composite surface represents the difference
between the two compared surfaces ( a point in the terrain is the
difference, e.g. 5280 - 10 = 5270).
4) Convert the composite surface to a terrain surface and you have your
guesstimated top of rock surface.
I wish to make two additional points:
1) Playing with the triangulation (flipping faces) of the borehole tin may
give you drastically different rock surfaces (based on limited coverage of
wide-spaced boreholes). Perhaps this process is easier and more interactive
in Civil3d, allowing you to play with alternatives.
2) With my experience with geology in New Mexico, I would never adopt your
hypothesis that the profile of the top of bedrock is in any way congruously
related to the top of topsoil profile. But your experience with geology in
your location may support your hypothesis.
Can this be done easier or differently in CIVIL3D? Maybe others will
contribute...
sc
Strahimir Antoljak wrote in message
news:FE2978F1CF422943E2C1CB9F55D5994F@in.WebX.maYIadrTaRb...
> anything else).
> detailed.
> PID values, etc).
> surface.
> figure.
> Thanks,
> Strah @ Langan
Message 3 of 14
congruously
in
well I definitely agree this is a tough issue to digest, and I am
sure this will be open discussion forever. I exaggerated
my sketch only for the purpose of making point of what
I would like to see available, or know how to accomplish.
I do not claim this is necessarily true. I heard geotechnical
engineers claim geotechnical engineering is more art than
engineering. Why? Because the investigations are done
point wise and then from what was found in discrete points,
educated guesses (or sometimes they may be less educated)
are done for the entire 'halfspace' - surrounding area.
(pretty bold guess I'd say).
Everybody ever been in touch with geotechnical engineering
is aware of that fact. That's why 'art' and that's why enormous
factors of safety as compared to some other civil engineering
disciplines (say structural engineering) - you really do not know
exactly what is going on under the surface.
Just as a comparison I will take Finite Element Analysis
(FEM). When something is modeled as finite element
model, everyone doing it is aware that the smaller the
finite elements are, the greater chances are to get more
accurate analysis results. But then it is costly (time consuming)
Or, you may have large elements and quick analysis.
In geotech engineering there are codes, and they may
require min 1 borehole per 5000 ft2 to 1 boring / 25000 ft2
or there may be some other constraints to require
more borings for the same area. But then it is
costly (money and time consuming) but of course more
accurate.
To conclude, this surface approximation is done anyway
(manually) either because project manager wants to include
that in their report or a client asks for that. To emphasize again,
everybody knows that what is among points is (an educated)
guess, and there is a big note accompanying such drawing
saying "THIS IS ONLY ESTIMATED ROCK SURFACE..."
or something of that kind.
What I am asking for is to have ability to do it quickly
and easily, maybe several versions of such 'educated guesses'
if possible and then let us users, based upon our accumulated
geotechnical/geological engineering experience decide how
accurate that is, and how to present it to a client.
There are such software on the market anyhow,
but I would like to see that option in Civil3D and use
one software rather than buy another too, and in my opinion,
with underlying Civil3D engine, it may not be even that difficult.
Thanks for you input,
Strah @ Langan
"Steve Cannon" wrote in message
news:6E3E8148D66BD2CCAD08374DF87A54D8@in.WebX.maYIadrTaRb...
> Hi,
point
would
creates
interactive
congruously
in
> contribute...
> sc
> > anything else).
> > detailed.
> > PID values, etc).
> > surface.
> > figure.
> > Thanks,
> > Strah @ Langan
Message 4 of 14
You point out one of the disadvantages of using a product that is targeted
at a wide user base. You don't find many tools that are written specifically
for one industry. While you will find software written with the geotechnical
field specifically in mind will do what you are looking for. The software
written for the Civil in general will not. What you might hope for is that
if there is enough market for it some one might write an add on for this.
I don't know anything about the geotechnical area. Does anyone use Ground
Penetrating Radar to get a better idea of the rock surface? I've seen GPR
used in Archeology.
Allen
"Strahimir Antoljak" wrote in message
news:BB4AD9D7968B2770411AC12B30170B41@in.WebX.maYIadrTaRb...
> Strah @ Langan
Message 5 of 14
> What you might hope for is that if there is
I apologize for being a little off topic, but does C3D include a VBA or LISP
API for new Land objects?
sc
Message 6 of 14
Well, I am surprised with that
much of attention for that matter.
I am just a person who does
not recognize discipline boundaries
that strictly these days. Many today's
projects are interdisciplinary and complex,
tend to show as many data in a single
project as possible, interacting among
different disciplines - site, architectural,
structural, mechanical, electrical, etc.
In our company this rock surfacing/contouring
is done with LDT, by a site/civil engineer,
manually estimating points 'in between'
and creating rock surface and contours.
Funny enough, I've also just gotten
an off newsgroup email alerting me
that capability I was asking
for, exists in another Site/Civil software.
So my thought is why not Civil3D as
well.
Strah @ Langan
"Allen S. Jessup" wrote in message
news:0BD3F6BF7F71B7F12BD8D048FED6F108@in.WebX.maYIadrTaRb...
specifically
geotechnical
> used in Archeology.
> Allen
> > Strah @ Langan
Message 7 of 14
The technique described by Steve should work equally well in Civil 3D.
Volume surfaces are the mechanism for "subtracting" two surfaces from each
other, so if you can construct a surface that represents "approximate offset
distance" you can subtract it from the existing ground surface to obtain the
result.
In Civil 3D the steps would be ( with credit to Steve for the steps that
I copied! )
2) Make a terrain surface representing Bore hole depths (a point would be a
2a) (Optional) use one of the smoothing methods to add interpolated points
to the bore hole surface ( this should help minimize the triangulation
problems that Steve mentioned ) Kriging would probably work best for this
because it does not depend on the existing triangulation, only on the point
coordinates and elevations. Choice of smoothing parameters could have a
significant impact on the results. Natural neighbor should give good
results if you're already satisfied with the triangulation and don't need to
add points beyond the extents of your borehole data. You could also
manually augment the borehole surface with aproximate points/edge editing
based on engineering knowledge of the local geology.
3) Create a Volume or Grid Volume surface using the top of ground surface as
the "Comparison Surface" and the bore hole surface as the "Base surface"
I'm pretty sure that there have been other requests for functionality
similar to your original request, but I'll pass your request on to the
surface team. If you have a specific interpolation method in mind that
isn't covered by the smoothing options, we'd like to hear about that as
well.
Chris Putnam
Software Engineer
Autodesk Civil 3D Team
Message 8 of 14
No reason why not other than it wasn't included in the menus. The underlying
software is certainly capable of it. Steve C.'s question about VBA & Lisp
addresses this. If these are available in C3D then it should be possible to
write a program that does thin inside the product. This problem should be
similar to offsetting a surface .
Allen
news:D400E84F38426434A04F4B749ECFE24E@in.WebX.maYIadrTaRb...
> well.
> Thanks,
> Strah @ Langan
targeted
> specifically
> geotechnical
software
that
this.
Ground
GPR
> > used in Archeology.
> > Allen
> > > Strah @ Langan
Message 9 of 14
Yes, there's a VBA API. Look in the samples directory under "Civil 3D
ActiveX" (or something like that) for some sample projects to get you
started.
Chris Putnam
Software Engineer
Message 10 of 14
Steve's approach will create a surface but Strahimir pointed out that there
may be only a few isolated borehole depths to rock. Interpolating between
these will not "follow" the surface very well.
But "guessing" some extra in-between points on the rock surface may be much
easier using Steve's method. You would only have to choose a "depth" to rock
at each new point which may be easier to do by inspection of the depths to
rock in the known boreholes surrounding the new point.
(PS What Steve, you haven't even been given a copy of Civil 3D ? Who *** have they got beta testing then ?)
Doug Boys Cardno MBK Brisbane Australia
Message 11 of 14
> Kriging would probably work best ...
> significant impact on the results...
> Natural neighbor should give good results...
> You could also manually augment the surface
> with approximate points/edge editing
In CD3, it sounds like more of the civil/survey profession is going to be
exposed to better interactive surface editing and program algorithms that
use geostatistic methodologies to estimate unknown surface values from known
surface values. I foresee polarized discussions over this issue in the
future. Over the past years in the LDD NGs , several 'purists' (such as
Laurie, Karl, and Bud) have been aghast that I actually advocated editing
surfaces and utilizing terrain points that were not 'known field points' in
my surfaces. Their position was that a surveyor was a collector of data and
that modeled surfaces must contain only data that was collected and
classified in the field as a random point or edge. They did not seem to
comprehend why a surveyor would ever need to manually edit a surface.
Understand, they were exposed only to the limited editing and triangulation
algorithms within LDD. Having experience with more sophisticated surface
editing tools, I put forth the stance that in these changing times, the
surveyors real job is the creation of the most accurate terrain surface
model possible that is most suitable to the client's needs - as long as they
can legally show a path back to field collected data and defend surface
creation and editing procedures. Once these guys have time with a more
sophisticated terrain modeler and interactive surface editing tools, it will
be interesting to see if they change their tune.
sc
Message 12 of 14
Probably a majority of Civil projects have only minor needs for sub-surface
data and hence Civil Based software does not necessarily address these
issues to the extent you require.
You would be more likely to find these sorts of issues addressed in Mining
software. Historically these types of programs are aimed at companies in
the 'Main-frame" computer budget range and hence not accessible to and often
not known to Civil firms which operate on far smaller budgets.
A company I visited in Quebec a couple of years ago has AutoCAD based mining
software in which these issues are very well addressed.
You may care to look at
http://www.promine.com
Laurie Comerford
CADApps
www.cadapps.com.au
> anything else).
> detailed.
> PID values, etc).
> surface.
> figure.
> Thanks,
> Strah @ Langan
Message 13 of 14
Hi Strahimir,
I can't tell you when it will be ready for Civil 3D - but we have a
fantastic application written exactly to your needs as described in our
SmartPack - Subsurface modeler, there is even a routine to draw borehole
diagrams based on mulitple surface strata.
It addresses the exact needs of subsurface interpolation based on borehole
data.
It currently is supported on LDT 3, and 2004.
You can download a free fully functioning 15 day trial version to evaluate
if it is suited to your needs.
You should certainly have a look.
http://www.pd5d.com/english/html/LDTapps.html
www.pd5d.com
Yours,
Natan
Technical Manager
PD5D.
> anything else).
> detailed.
> PID values, etc).
> surface.
> figure.
> Thanks,
> Strah @ Langan
Message 14 of 14
hi,
hmmm.... not quite.... the offsetting
is related to constant distance between
two lines or surfaces in this case.
However, a field investigation can
show that rock is found at depth
7ft at point A, and at depth 12ft at
point B. So, 'offsetting' would not be
much of a help here.
thanks
Strah @ Langan
news:79DCEEB860B9E7D9AE66DBE64EFAD28D@in.WebX.maYIadrTaRb...
underlying
to
> Allen
> > well.
> > Thanks,
> > Strah @ Langan
> targeted
> > specifically
> > geotechnical
> software
> that
> this.
> Ground
> GPR
> > > used in Archeology.
> > > Allen
> > > > Strah @ Langan
Rail Community
