I am looking for road signs, ie county roads, stop signs etc.
Where would a guy look for the signs, be blocks or xref?
Is there away to use the sign images fro ArcView?
Solved by AllenJessup. Go to Solution.
You can buy the Digital MUTCD that includes AutoCAD blocks http://www.fhwa.org/en/products/mutcd/mutcd_cad_en.html
Suposedly these prople have them for free http://mildpdf.com/file/group/mutcd-signs-in-autocad.html
Allen
Allen Jessup
Engineering Specialist / CAD Manager
@manmonza wrote:I am looking for road signs, ie county roads, stop signs etc.
The sign images in E$RI are fonts just create a text style using one of those add some text then either explode the text or wmfout and back in to create the blocks as needed. I created a ton of them years ago that way. If yours are not font type but BMP you need Raster Design, but a few command signs are in the ArcPad font.
I don't see the free signs in your link Allen. Can you verify?
Neil,
No I can't. I believe you mean the non-MUTCD link. I only got a quick look at their front pabe and then was blocked by our firewall. I don't know why, because we ARE a Highway Department. But IT is funny that way.
It's possible that things have changed since Mar 2011.
Allen
Allen Jessup
