Civil 3D Forum
Road modelling help - Grading or corridors?
4 REPLIES 4
normans
506 Views, 4 Replies
Hi all,
Appreciate your time and comments:
I am preparing to model a road surface for a waterline project.  I would like to be able to generate sections at desired stations showing the sewer, storm drains and joint utility trench along with the proposed water line. My plan is to model the road surface using a surface created from gradings and then create the pipe networks and joint trench.
My question is whether gradings or corridors would be the way to proceed.  I have preliminary design data on the road surface which is sure to change.  Any comments greatly appreciated - would like to start with a good workflow.
Civil 3D 2015 SP 2, 64 bit
Dell Precision T5600, 16 GB
Win 7 Professional 64 bit
Intel Xeon @ 2.0 GHz
NVIDIA Quadro 4000
4 REPLIES 4
Joe-Bouza
in reply to: normans
Corridors are not just for roads but it is what they do.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
ksorsby
Gradings are pretty buggy (in my experience anyway) for anything remotely complex, so I'd corridor all the way if it were me.
Kevin
normans
in reply to: ksorsby
Thanks for the advice.
I have a little experience with corridors and will use them for this project. I may try and use a corridor to model the joint trench also.
Thanks again!
NVIDIA Quadro 4000
castled071049
I totally agree with ksorsby... corridors are DEFINITELY the way to go here.
Rail Community
