The length you can design is far less critical than the number of
cross-sections the program has to handle.
100 km of road with sections every km will require less computation than 1
km with sections every metre.
Another issue is that the alignment will go out of kilter with the fact that
the earth in not flat once it's length exceeds a few kilometres.
In the same sense, your surface model will be far more sensitive to the
number of triangles, than to the overall plan dimensions and elevation
range.
Laurie Comerford
CADApps
www.cadapps.com.au
www.civil3Dtools.com
wrote in message news:5675981@discussion.autodesk.com...
Is there a limit on the length of road project that can be designed using
Civil 3D.
