Civil 3D Forum
Road design criteria
5 REPLIES 5
RalphBrown99
1189 Views, 5 Replies
Hi:
Please someone talk to me a a place where I can find standards for road design (either rural or urban) including criteria files with that standards that I can use in Civil 3D -These files could be read from the Alignment Properties Window<Design Criteria Tab- These code could be delivered by AASHTO or another institute.
Rafael
5 REPLIES 5
Pointdump
in reply to: RalphBrown99
Rafael,
C3D has built-in AASHTO standards. Road design is not my specialty, but I think a look through the Help Section would enlighten you.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
sboon
in reply to: Pointdump
If you select an alignment in your drawing you should be able to find the Design Criteria editor on the Ribbon.
The default files are stored in C:\ProgramData\Autodesk\C3D 2014\enu\Data\Corridor Design Standards\  You can copy and edit them to match your local requirements.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
RalphBrown99
Thanks for your help!
RalphBrown99
in reply to: sboon
parteekwitt
in reply to: sboon
Hi there,
I am learning autocad civil 3d. While designing the road I applied design speed to the my alignment.
My question is what changes are applied by the autocad when design speed changes?
Rail Community
