Hi, i am a new user of Civil 3d so maybe here i will sove the mistery :). So i made the alignement, then calculated the superelevation, created the superelevation view (where i can see that the superelevation is created). Made the longitudinal section (profile), made the assembly, corridor, coridor surface, sample lines .... then my issue. I made also the cross sections but the problem is that in the cross section view, all the sections are with the same slope as the assembly. So i want to see in the cross section view, the superelevated section as i can see it in the superelevation view (and i can't ). What am i doing wrong? i try to do this for several days now, and i still can't. Please HELP !
Thank you !!!
Solved by Jay_B. Go to Solution.
Subassemblies which support Superelevation must be used such as the "LaneSuperelevationAOR".
And the "Use Superelevation" Parameter must be set within each subassembly in order for the slopes to honor the Superelevation slopes.
By right clicking on any subassembly on the Tool Palette choose Help and available parameters including superelevation are listed if available for a given sub.
