Employee
34 Kudos
Post 61 of 150
Re: River Analysis Extension for AutoCAD Civil 3D / AutoCAD Map 3D
06-14-2012 04:54 AM in reply to: jmayo
Yes, River Analysis can read in the HEC-RAS project file and then can load the results for floodplain mapping.
Matthew Anderson, PE
Product Manager
2 Kudos
Post 62 of 150
06-14-2012 05:01 PM in reply to: scott.sheppard
Thanks Mathew,
OK I think I have found that option now for writing out the floodplain lines. Ta.
Regards
Dean Petersen
Valued Contributor
7 Kudos
Post 63 of 150
07-19-2012 04:35 PM in reply to: scott.sheppard
Any News on a version for 2013?
Paul
Paul R. Mascaro
CAD Supervisor | Engineering Design
ENVIRON International Corporation
System: Dell 6800M, OS | MS Windows 7 64-bit SP1, CPU | Intel Core i7 Gen4 @ 3.00GHz Haswell 22nm, RAM | 32.00 GB DDR3 1600 MHz, Graphics | NVIDIA Quadro K5100M (8 Gig), HD | SSD Master, SS Hybrid Secondary
*Pro
180 Kudos
Post 64 of 150
09-18-2012 03:15 PM in reply to: scott.sheppard
Does this work with C3D 2012 SP2.1 ?
Fred Ernst, PE
C3D 2015 SP2
Ernst Engineering
www.ernstengineering.com
9 Kudos
Post 65 of 150
09-19-2012 07:33 PM in reply to: fcernst
Fred;
Yes, River Analysis works with latest the AutoCAD Civil 3D 2012 service pack.
Did you encounter this error when opening a prior drawing or just on launch.
*Pro
180 Kudos
Post 66 of 150
09-19-2012 07:54 PM in reply to: subsales
On launch. Sent from my iPhone
Fred Ernst, PE
C3D 2015 SP2
Ernst Engineering
Employee
34 Kudos
Post 67 of 150
09-21-2012 08:05 AM in reply to: Matt.Anderson
Fred -
I would suggest uninstalling and reinstalling River Analysis, but it launches, and imports without issue on SP2.1.
Product Manager
*Pro
180 Kudos
Post 68 of 150
09-21-2012 08:47 AM in reply to: Matt.Anderson
Matt,
I did that before my first message, and just reinstalled again this morning and still get the "unexpected error quitting" message. I am also getting this message when closing the program.
Fred Ernst, PE
C3D 2015 SP2
Ernst Engineering
Employee
34 Kudos
Post 69 of 150
09-21-2012 09:07 AM in reply to: fcernst
I assume you had it working prior to SP2.1?  The first download of extension expired in December, and the latest version extended that original date.  I assume you have the latest download.
For installation, check prior posts to verify that the files are copied correctly and your River Analysis icon has the necessary Administrative privileges.
As for the last error, its a bit difficult to tell what didn't close prior to AutoCAD Civil 3D closing. Its a benign error.
Product Manager
*Pro
180 Kudos
Post 70 of 150
09-21-2012 09:28 AM in reply to: Matt.Anderson
I just right-clicked on the imperial icon now and ran as administrator as you suggested and it launched without that error.
Yes I did have it running before.
Thanks for the help Matt.
Fred
Fred Ernst, PE
C3D 2015 SP2
Ernst Engineering
