Civil 3D Forum
River Analysis Extension for AutoCAD Civil 3D / AutoCAD Map 3D
151 REPLIES 151
Message 1 of 152
scott.sheppard
13822 Views, 151 Replies
There is a new technology preview on Autodesk Labs.
http://labs.autodesk.com/utilities/civil3d_river/
Project River Analysis Extension for AutoCAD® Civil 3D® 2012 software and AutoCAD® Map 3D® 2012 is a sophisticated river modeling software package supports HEC-RAS within the AutoCAD Civil 3D 2012 and AutoCAD Map 3D 2012 environment. This technology preview of River Analysis makes it easier than ever before to compute water surface profiles for modeling rivers, bridges, culverts, spillways, levees, floodplain and floodway delineations, stream diversions, channel improvements, and split flows.
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
151 REPLIES 151
Message 41 of 152
gperego
in reply to: wfberry
Hi all,
Thanks Bill for your suggest, but in my Start-All menu I haven't any icon for RAE.
I rebuilt it manually with this from the Civil 3D one with this destination:
"C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\acad.exe" /ld "C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\AecBase.dbx" /p "<<C3D_Italy>>"
And especially from:
"C:\Program Files\Autodesk\Project River Analysis 2012"
I found also the Icon, in the RAE folder.
The link for myGIS&INfrastructure  Blog is:
www.bimacademy.it/gis
You can read it using Google Translate.
Regards
Many thanks!
Giovanni from Tech Data Italy
Message 42 of 152
mjung
in reply to: gperego
Finally recieved some HEC/RAS info to try out in the program!!! All seemed to be working well until I tried to "Compute Analysis"
I was able to Import the HEC/RAS project. It seemed to draw all the components (reach, profiles, cross sections) All the section had data that matched the rersults in HEC/RAS etc... but when I clicked on "Compute Analysis" it gives the error message:
Run-time error '429':
Active X Component can't create object
Any help would be appreciated.
Edit: This is being done with Civil 3d 2012 (32bit) and Windows XP if it matters.
Civil 3D 2024 / Windows 11 Pro (64bit)
Intel Core I7 @3.30GHz / 32gig RAM / NVIDIA Quadro K2200
Message 43 of 152
wfberry
in reply to: mjung
I believe the current River Analysis 2012 is for 64 Bit Civil 3D 2012 or 64 Bit Map 3D 2012.
Bill
Message 44 of 152
mjung
Thanks for the reply. I was going over the install and remembered that one of the files failed to register. So that could also be the issue.
I tried the Retry multiple times but finally hit the ignore. I wonder if there is a way to manually register this file? If not it looks like a re-install might be coming...
Message 45 of 152
Matt.Anderson
in reply to: mjung
What operating system did you install on?
Did you turn OFF User Account Control to install?
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Message 46 of 152
mjung
in reply to: Matt.Anderson
This was on Windows XP so the "User Account Control" isn't applicable. I do have full admin privileges on the account.
Message 47 of 152
jmayo-EE
in reply to: mjung
I played around with this last week and hit a brick wall with an 'Error Loading Geometry File' (from HEC Ras) when I ran the computation.
The app really needs to work with C3D objects (alg, profiles and sections).
The app did not like 2d or 3d polylines for a 2 stage weir I had to model.
Overalll I loved the product and the workflow.
John Mayo
Message 48 of 152
hng
Community Visitor
in reply to: mjung
I have the same issue. I was able to import XS from Hac Ras, however when I run it, I see the same error message, can somebody tell me what to do? Thanks!
(my system info
 Intel Xron Processor 3.07 GHZ
Winow 7 64-bit
Nvidia Quadro 2000)
When I start the program, I will see this mesage
Message 49 of 152
fadi_k
in reply to: scott.sheppard
is there a tutorial out there for this?
thanks
Message 50 of 152
in reply to: hng
@hng: try starting as administrator. I think river analysis is trying to create files in UAC protected area.
Message 51 of 152
jmayo-EE
in reply to: fadi_k
There are videos on the download page and the help file covers it all.
John Mayo
Message 52 of 152
hng
Community Visitor
@BHFH, it works, Thanks Alot
Message 53 of 152
Hi;
 i want to know is it designed to perform two-dimensional hydraulic calculations for a full network of natural and constructed channels or its one-dimensional hydraulic calculations software similar to HEC-RAS!?
Mehrdad
Message 54 of 152
Matt.Anderson
in reply to: jmayo-EE
Mehrdad -
River Analysis is HEC-RAS within Civil 3D and/or Map 3D.
Product Manager
Autodesk (Innovyze)
Message 55 of 152
It would be nice if the RAE could be linked to alignments with the ability to set the centerline as a certain station from which the left to right section stationing could be derived by the computer and not have to be input.
I.E.  Using a defined alignment with centerline being the 0+00 or 1+00 for all sections then station label, length between stations, station of all sections could be defined by just clicking on the section lines that I plot along my alignment.  This would give my section plotting some relative reference to centerline.
Currently I have to define an alignment, label all of the sections and the offset at the end right of the section (downstream left), then reenter all of that info as my starting section.  It would seem the computer could do all of that for me if it had a definited alignment.
I've seen reference to avoiding negative stations in cross sections, which I have done in the past, but it would be prefered from my POV to have neg be downstream left and positive downstream right of CL.
Steve Lewis, PE
Message 56 of 152
cwitzel
in reply to: SteveLewis5729
I second this.
As it stands right now, the Center line of the reach almost appear to be random.  I am selecting it to automatically cut the sections, why can't this be stored in the reach.  An Alignment would be even better.
The HEC-RAS text file supports a centerline.
Conan Witzel
Civil 3d 2021 SP1.1
Smoking BOXX Apex 2 Workstation
Message 57 of 152
Now that AutoCad 2013 is here, where is River Analysis 2013? How long do we wait? I really anticipated that RA would be part of the release. Well...
Message 58 of 152
mathewkol
It's Labs software. You really can't expect much. Maybe we'll get it, maybe not. That's the nature of Labs. I assume there's some kind of NDA agreement which would negate getting any answer as to if/when it will happen.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 59 of 152
scott.sheppard
The technology preview is conducted so that the River Analysis team can get feedback on the technology. Right now they are getting plenty of feedback from the AutoCAD Civil 3D 2012 user base. If they decide they would like to expand the audience to collect additional feedback, they may conduct a 2013-based technology preview.
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
Message 60 of 152
Is it possible to read in a HEC RAS analysis that has already been calculated in HEC RAS, and have the results displayed using the RAC tools in Civil3D?
I can't seem to see a way of doing that. Thanks.
Regards
Dean Petersen
Rail Community
