Civil 3D Forum
River Analysis 2014 Apparent Junk
11 REPLIES 11
Message 1 of 12
rhschneider
2043 Views, 11 Replies
Am really frustrated with lack of documentation.
Create bridge opening @ dwnstrm section. Input data.
Input data for upstrm section.
Input all other garbage.
Bridge is on skew. Upstrm & dwnstrm sections are parallel to bridge i.e not normal to flowline.Each section is offset 1 ft from bridge face.
Run compute
See error messages below
Very diappointed in quality--really sucks!!!
Thought this was really going to save time as well as create valuable dwgs.
Right now the ony value I see is to cut sections in surface and export to HECRAS and finish in HECRAS.
Very expensive section cutter!!!!!
Generating HEC-RAS data file F:\13.0026.01-CTH DE Bridge Replacement\Survey\HECRAS ANALYSIS(CIVIL 2014).RDT.
Reach 1
Initial data check...Finished
ERROR: River: "River #1" Reach: "Reach #1" RS:230 BR  (DID NOT CREATE)
 - Deck data needs at least two station - high elevation points.
 - Bridge does not contain an opening on the upstream side.
 - Bridge does not contain an opening on the downstream side.
River: "River #1" Reach: "Reach #1" RS:196.5 BR
 - Bridge/Culvert has an upstream distance of zero, HEC-RAS requires a positive distance between the upstream cross section  and the face of the bridge. A zero distance was allowed in versions prior to 3.0. A table was added to the geometric data
 editor to facilitate global editing of bridge distances and widths. Some length will need to be added to the upstream
 distance column and an amount greater than that will have to be subtracted from the bridge width column. (DID INPUT DISTANCE)
 - Deck data needs at least two station - high elevation points. ??
 - Bridge does not contain an opening on the upstream side. ??
Detail data check...Failed
Cannot generate HEC-RAS data file.
11 REPLIES 11
Message 2 of 12
rhschneider
in reply to: rhschneider
I cut sections in River. Then exported to HEC. Then finished data input in HEC. Ran compute. Imported HEC file to River. Ran compute.
Results:
Reach 1
ERROR: River: "River #1" Reach: "Reach #1" RS:75 BR Bridge is at 196.5
 - Deck width not set.
Command:
Message 3 of 12
rhschneider
Turned off bridge openings. Ran compute. Ran ok. Turned bridge opening back on and computed ok. What's going on??
Message 4 of 12
Hidden_Brain
i am yet to use River Analysis so cannot help you there. I use the HEC-RAS extension or hec-georas (when the horizontal variation is of N values is large), but always find coding the structures manually better than any automated procedure. measure the structure from u/s bounding section, set up a spreadsheet to calculate ineffective flows, and drape a feature line to get the high chord, always works for me. my $0.02...
Message 5 of 12
nturner
I hope Autodesk puts some time into this b/c it could be really cool.  A way easier to visualize solution than HEC.  Especially with Infraworks and integrating into that.  If you do a bunch of river modeling, there is a cool 2D plug-in for infraworks that is coming out soon Project Boulder they call it; https://www.youtube.com/watch?v=LTsE2uTiztk
But right now I'm having a tough time getting by the same error message about upstream distance being zero.
Message 6 of 12
nturner
Figured out my issue that may be helpful to others.  If you put in a culvert, you have to define a 'Roadway' as well.  Then the U/S X Section distance in the culvert editor, is actually the U/S distance from the roadway you define.  There really is no documentation of this Module, and the User's Manual is really vague.  It is a cool program though and hopefully it gets even cooler.
Message 7 of 12
Pointdump
in reply to: nturner
NT,
"...no documentation of this Module..."
Did you look <<<Here>>>?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 8 of 12
Hidden_Brain
Thanks for sharing the info. I suppose it makes sense, you cannot run a culvert analysis in HEC-RAS without coding in the bridge deck (roadway), as far as I know.
Message 9 of 12
fcernst
Needs to work with 5.0 now
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 10 of 12
Matt.Anderson
in reply to: fcernst
Fred -
Define 'work with'....
Short of running the 5.0 engine - the export and import works with 5.0.
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Message 11 of 12
Hidden_Brain
Sure would be nice to be able to create geometry for combined 1d-2d in civil 3d and export.
Message 12 of 12
jmayo-EE
in reply to: Matt.Anderson
I get a lot of HDS errors when I compute files in 5.0 exported from River and Flood. I need to recreate the models to get them to actually run.
It would be real nice if River and Flood used Hec Ras 5.
John Mayo
Rail Community
