hi all
Is there a quick way to do a rise and lower of a section of a featureline with out using the elevation editor.
I just want to click say a start and end point and be prompted for how much to rise and lower the vertices by in this section.
Regards
Justin
Not elegant but paste the surface they create into a temp raise it and use the partial option from surface?
Your Name
Your Name
Alternate solution - also not elegant.
Break the featureline just beyond the segment you want to edit. Raise or lower that piece then grip edit and rejoin to the original.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
John,
I hadn't noticed that one before. Thanks.
Dave
Dave Stoll
Las Vegas, Nevada
