Civil 3D Forum
RIGHT EDGE- CENTRE EDGE AND LEFT EDGE levels of vertical alignment
13 REPLIES 13
Message 1 of 14
2286 Views, 13 Replies
Hi
I have a problem with my profile view and was wondering if anyone can help me please. I’m using a South African template which I cannot seem to get the RIGHT EDGE- CENTRE EDGE AND LEFT EDGE levels of my vertical alignment when creating my profile. All the levels seem to stay the same. I have created an assembly with a -2% and a -2% fall. I also attached a drawing. Can anyone please help me with this problem?
Jameel Pathan
13 REPLIES 13
Message 2 of 14
Joe-Bouza
in the profile view properties on the data band tab make sure your assigning left right and center to the appropriate slots
Joe Bouza
Message 3 of 14
I have tried that and still the Right, left and centre edge stays the same.
Message 4 of 14
Joe-Bouza
Are they superimposed profiles? can you post the drawing?
Joe Bouza
Message 5 of 14
Hi
The file is too big too send I attached the pdf file. Its just a normal Profile.
Thank You very much
Message 6 of 14
Joe-Bouza
If you want to email me
jbouza <at>cameronengineering <dot><com>
Joe Bouza
Message 7 of 14
I have the exactly the same problem. The left and right edges on my profile are the same as the centreline levels.
What was your solution to the problem?
Message 8 of 14
Joe-Bouza
Post a screen grab of the profile data band properties dialog
Joe Bouza
Message 9 of 14
in reply to: Joe-Bouza
The left and right edge are referenced to the centreline geometric data.
Message 10 of 14
doni49
Your right, left and center all reference the SAME PROFILE.  SAME PROFILE = SAME INFO.
EDIT:  I just re-read your post and realized that you had already figured it out and just came back to explain what the issue was.  Sorry.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 11 of 14
in reply to: doni49
Superelevation data is correct and appears in the profile view, but the road left/right edges levels are incorrect and are the same as the road centreline levels.
Message 12 of 14
in reply to: doni49
Message 13 of 14
Hie i am facing the same challenge of producing the same road levels for right edge and center and left edge is there a way including the centre line offset data  into the profile view band
Message 14 of 14
tonderaitmaworera
in reply to: doni49
How to you add the offset alignments to the profile which you could have created from centerline
Rail Community
