Not sure what happened, but my right click short cut menu is no longer working. I have verfied my right click customization under options and also confirmed that "pickfirst" is on. It was working and then just quite. I have restarted the computer several times but status remains unchanged. Anyone got any ideas as to what is going on and how to get it correct?
Scott
Hi Scott,
Have another user login to your system with his login credential and and if he does not face the same issue, you may want to reset your user settings by following the steps provided in the link here.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19170578&linkID=9240697
The steps for different version of Civil 3D are provided at the bottom, you may want to click the appropriate version of yours.
