Civil 3D Forum
Ribbon turns green and freezes the program; MTEXT not work !!!
3 REPLIES 3
Paul_Reyes
1082 Views, 3 Replies
Hi, I have two problems with Civil 3D 2012. The first is that when I edit a MTEXT I get abox that says:
The second problem is that when working with the ribbon, it turns green and freezesthe program, and I must reboot to continue working ...
There will be some service pack for these mistakes uncorrected??
Tags (2)
3 REPLIES 3
AlmasSuljevic
in reply to: Paul_Reyes
Can you type DTEXTED and set it to 1? See if that helps unlocking. Also hit CTRL key to see if that helps.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
mathewkol
There could be a service pack if it's determined that the problem is reproducable.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
hgohel
Is it possible that you have some third-party add-ons for Civil 3D which aren't built especially for Civil 3D 2012?
Himanshu Gohel
Autodesk, Inc.
Rail Community
