Civil 3D Forum
ribbon and panels not loaded
3 REPLIES 3
291 Views, 3 Replies
Opened up my Civil 3D this morning and this is what i got.
The Ribbon does not have any tabs or panels currently loaded.
Thanks for any help
3 REPLIES 3
rkmcswain
What is your main menu?  It should be "Civil" (C3D.Cuix), unless you've done some customization that could cause this to not be the case.
I've seen the menu get corrupted on some machines in the past.
If it appears the correct Civil menu is in place, you might try a restore.
in reply to: rkmcswain
I found the cd3.cuix but it says the file has been renamed or deleted. i
renamed this cd3orig.cuix
I found a cd3.bak.cuix and renamed it cd3.cuix. I typed in cui in the dwg
and found loaded the renamed one and it shows up on thr cui now but when i
push apply it still does'nt bring up the ribbons. Just not sure how to get
the machine to use the cd3.cuix
Darla Bowers
Engineering Division
City of Wichita Falls, Texas
office 940-761-7421
fax 940-761-6873
darla.bowers@wichitafallstx.gov
mathewkol
Make sure that one of the workspaces within the CUIX file is set as current.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Rail Community
