Valued Contributor
rcallison
Message 1 of 5 (168 Views)
Revise Stationing
168 Views, 4 Replies
12-10-2012 10:54 AM
How do I revise the profile stationing from 100+00 to display 100.
Also is it possible to remove the begining and end stations in the profile view
I have attached an example
Rick
Jeff_M
Message 2 of 5 (160 Views)
Re: Revise Stationing
12-10-2012 11:11 AM in reply to: rcallison
It's all in the styles:
troma
Message 3 of 5 (159 Views)
Edit your Pofile View Style.
go to the Horizontal Axes Tab, where it says Tick label text click on the edit button on the right (with an 'A' on it)
Hightlight the text that is there, and look at the options on the left.
At the bottom (in my version anyway) is the 'Output'
Switch this to say 'left of station character' and then click on the arrow at the top to replace the text with the change you made.
Click Ok, Ok.
Credit where credit is due! Give kudos or accept as solution whenever you can.
troma
Message 4 of 5 (158 Views)
12-10-2012 11:14 AM in reply to: rcallison
Also in the Horizontal Axes Tab I see the option to tick and label start station.  I don't see an option for the end station though.
Jeff_M
Message 5 of 5 (149 Views)
12-10-2012 11:32 AM in reply to: rcallison
And to turn off the start/end station label, turn off the bottom axis labels and use a Band to label the stations instead. You can then determine to use the start/end stationing.
