Civil 3D Forum
Revise layouts in sheet sets
2 REPLIES 2
rconway
274 Views, 2 Replies
I have made a model with 40 viewframes.  I have used the option to export 4 layouts to one drawing.  My question is can I revise the original model and get the revisions automatically updated in the 10 drawings or do I have to redo the export option?
Ron C
2 REPLIES 2
AlmasSuljevic
in reply to: rconway
Have you seen this: http://forums.autodesk.com/t5/AutoCAD-2007-2008-2009-DWG/Auto-page-numbering-bases-on-layout-tab-con...
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
tomshumpert
As long as you dont change the name of the Layout Tabs it should still be linked in sheet set with fields.
The exported layouts were imported into sheet set?
Typically you would only want to have one Layout per drawing. If that drawing crashes it takes out more than one of your drawings.
Tommy Shumpert -
Civil3DiT | Twitter
Rail Community
