I have made a model with 40 viewframes. I have used the option to export 4 layouts to one drawing. My question is can I revise the original model and get the revisions automatically updated in the 10 drawings or do I have to redo the export option?
Ron C
Have you seen this: http://forums.autodesk.com/t5/AutoCAD-2007-2008-2009-DWG/Auto-page-numbering-bases-on-layout-tab-con...
As long as you dont change the name of the Layout Tabs it should still be linked in sheet set with fields.
The exported layouts were imported into sheet set?
Typically you would only want to have one Layout per drawing. If that drawing crashes it takes out more than one of your drawings.
