Civil 3D Forum
Reverse Vertical Curve Label
2 REPLIES 2
nostupidquestions
828 Views, 2 Replies
How do you guys handle a PRVC label? Right now I have the PVC and PVT labels on top of each other. Is there a nice solutioon other than making a new label style? Thanks.
Intel(R) Xeon(R) W-2245 CPU @ 3.90GHz 3.91 GHz
64 GB RAM
C3D 2023.2
2 REPLIES 2
sjg
in reply to: nostupidquestions
Looking at my styles, I do the same thing you did, actually typed PVC and PVT within the text component. Couldn't find an option that would use the abbreviations from the drawing settings. Looked at the out of the box template for profile labels they did the same as us, but within the alignment labels, they were able to choose Geometry Point Text, which uses the abbreviations for the point type. Not sure why it is not included in profile labels, with that text component, label would always change based on the actual point type.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
klugb
How did you get a "true" PRVC? C3D won't allow it and there has to be a small gap between the curves.
We label crest curves above and sags below so the labels don't overlap.
Bruce
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2023.2.1
Win 10 Enterprise, 64-bit
Rail Community
