I know what you are referring to, well I think I do.
Two years ago I wrote a white paper for a friend’s blog (Doug B) on the topic but it never made it to press.
Anyway here is the workflow using either a xsl or VBA app. (all included in the attached zip)
Enjoy
This is exactly what I need. Noobie question, where do i put the files to get them to show up in the reports genereator. Im running 2011.
are you looking to draw the profile starting at the high station on the left and move toward the low station on the right? If so, then just change the profile view style to draw from Right to Left (the default is Left to Right). The first post in this thread is very old and the solution are out of date.
Peter Funk
Autodesk, Inc.
My situation is exactly as above. And without getting into the detail as to how we arrived at this point, generating the profile in reverese simply wont help in this instance. While the first post is indeed old its not an out of date problem and the solution was posted last June. I have almost 3km's of mountain road designed and i dont want to have to copy, explode and redefine to make it work. Thans though for the suggestion.
Yes!, I remember now, The issue was that when you reversed the direction of the Horz alignment, the Vert design profile did not reverse as well. I was so sure that this was fixed or at least an out of box solution.
I just looked at 2011 and it seemed to be the same. So I do not know what I was thinking.
To answer your question following are the steps to set up the XSLT
hope this works, this XSLT was written for 2007, not sure if all the references will still work.
If not, when I get a chance I can look at it, let me know.
However, If I understand your issue correctly, it has to do with the reversing of the profile data, in which case the VBA program is your solution and not the XSLT file.
The XSLT was for outputting the vertical align profile
The VBA was for outputting the vertical align profile while applying an offset and/or reverseing the direction.
Hopefully I am missing something in 2011 and someone else has a better solution in 2011
