AutoCAD Civil 3D General Discussion
Valued Contributor
bgriffin291
Message 1 of 3 (1,554 Views)
Reverse Pipe Start and End
1554 Views, 2 Replies
06-28-2011 10:00 AM
I need to flip or reverse the start and end of a section of arch pipe.  I guess I drew them in backwards, thus my labeling is backwards, i.e. upstream invert is lower than downstream invert.
Reversing the flow direction does nothing as the start and end elevations are still the same.
Any suggestions?
Valued Contributor
MichaelMerlino7407
Message 2 of 3 (1,541 Views)
Re: Reverse Pipe Start and End
06-28-2011 10:44 AM in reply to: bgriffin291
Reversing the flow direction makes the pipe slope positive or negative. It will not change the elevations, but it changes which side is used to calc the slope.
Michael Merlino
Civil Engineering Technician / "CAD Manager"
SAN JOSE, CA, USA
Distinguished Mentor
andrewpuller3811
Message 3 of 3 (1,497 Views)
06-29-2011 08:06 PM in reply to: MichaelMerlino7407
After reversing the pipe direction, select the pipe, right click and select apply rules. This should adjust your inverts.
If this fixed your issue, click on "Accept as Solution"
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
