Civil 3D Forum
Reverse Pipe Start and End
2 REPLIES 2
bgriffin291
5664 Views, 2 Replies
I need to flip or reverse the start and end of a section of arch pipe.  I guess I drew them in backwards, thus my labeling is backwards, i.e. upstream invert is lower than downstream invert.
Reversing the flow direction does nothing as the start and end elevations are still the same.
Any suggestions?
2 REPLIES 2
Reversing the flow direction makes the pipe slope positive or negative. It will not change the elevations, but it changes which side is used to calc the slope.
Michael Merlino
Civil Engineering Technician / "CAD Manager"
SAN JOSE, CA, USA
After reversing the pipe direction, select the pipe, right click and select apply rules. This should adjust your inverts.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Rail Community
