I need to put a reverse curve on an alignment. I have tried using two free curve fillets,(beetween two entities, radius).the first curve was fine, but it would not allow the second curve. I also tried using a floating curve ( from entity radius through point) first, but it did not work.
The floating curve and free curve combination should work. Make sure that the floating curve is longer than necessary so that the software is able to solve for the intersection point with the free curve.
Sometimes it is easier to start by creating a set of curves that don't have the radius you want but will definitely work geometrically. I started this one with a 250m floating curve and I'm going to use a 500m free curve for now. Once it's built I can drag things around and edit them to suit.
