Civil 3D Forum
Reverse a linetype
10 REPLIES 10
Message 1 of 11
1930 Views, 10 Replies
Reverse a linetype
I have a polyline in my drawing, consisting of arcs and lines all joined together. It is a waterline and I cannot get it to reverse.. it is reading ----M----- instead of -----W-----
10 REPLIES 10
Message 2 of 11
tcorey
Perhaps your linetype definition uses a U value for angle, so the text remains upright (to the U value, so 180 would make it upside down) no matter how the object is rotated. Take a look at the linetype file and see if this could be your issue.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 11
mathewkol
How are you trying to reverse it?
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 4 of 11
tcorey
in reply to: mathewkol
Matt, I assume he used the Reverse command. That doesn't work on U-coded linetypes.
Tim Corey
Redding, CA
Message 5 of 11
rkmcswain
Its possible that the OP does not have the .LIN file.
In that case, you could use TO-LIN.LSP to extract the linetype definition to a file for inspection.
http://www.turvill.com/t2/free_stuff/to-lin.lsp
R.K. McSwain     | CADpanacea | on twitter
Message 6 of 11
mathewkol
Tim, indeed, I'm just covering the hopefully obvious.
OP, there is a REALLY annoying problem with the feature Tim spoke of. If your view is not North up could have a situation where no linetypes are upright.
I avoid them and create a copy of the linetype where the text is rotated 180 degrees.
Matt Kolberg
Message 7 of 11
The solution to this ended up being simple. Once selecting the line, in the bottom of the properties box there is an option for "Linetype Generation", it was disabled. Once enabling, all was fixed.
Thank for the suggestion guys!
Message 8 of 11
tcorey
Boy do I feel dumb for not getting that one! I knew that contolled where the patterns fall, but I had no idea it would affect the rotation of the lettering. So, in your linetype, you're using U coding for angle, plus Linetype Generation turned on?
Tim
Tim Corey
Redding, CA
Message 9 of 11
in reply to: tcorey
I'm a girl. 🙂 Aubrey Betts CAD Technician Lennon, Smith, Souleret Engineering, Inc. 846 Fourth Avenue, Coraopolis, PA 15108 (412) 264-4400 Ext. 205 www.lsse.com
Message 10 of 11
in reply to: tcorey
It seems so. I didn't know this either but whatever works I suppose! Aubrey Betts CAD Technician Lennon, Smith, Souleret Engineering, Inc. 846 Fourth Avenue, Coraopolis, PA 15108 (412) 264-4400 Ext. 205 www.lsse.com
Message 11 of 11
I was just typing in "reverse". It typically works. Aubrey Betts CAD Technician Lennon, Smith, Souleret Engineering, Inc. 846 Fourth Avenue, Coraopolis, PA 15108 (412) 264-4400 Ext. 205 www.lsse.com
Rail Community
