abetts
Message 1 of 11 (491 Views)
Reverse a linetype
491 Views, 10 Replies
12-17-2012 12:14 PM
I have a polyline in my drawing, consisting of arcs and lines all joined together. It is a waterline and I cannot get it to reverse.. it is reading ----M----- instead of -----W-----
tcorey
Message 2 of 11 (485 Views)
Re: Reverse a linetype
12-17-2012 12:32 PM in reply to: abetts
Perhaps your linetype definition uses a U value for angle, so the text remains upright (to the U value, so 180 would make it upside down) no matter how the object is rotated. Take a look at the linetype file and see if this could be your issue.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
mathewk
Message 3 of 11 (463 Views)
12-17-2012 01:31 PM in reply to: abetts
How are you trying to reverse it?
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
tcorey
Message 4 of 11 (450 Views)
12-17-2012 02:14 PM in reply to: mathewk
Matt, I assume he used the Reverse command. That doesn't work on U-coded linetypes.
Tim Corey, Owner
Redding, CA
rkmcswain
Message 5 of 11 (445 Views)
12-17-2012 02:30 PM in reply to: abetts
Its possible that the OP does not have the .LIN file.
In that case, you could use TO-LIN.LSP to extract the linetype definition to a file for inspection.
http://www.turvill.com/t2/free_stuff/to-lin.lsp
mathewk
Message 6 of 11 (426 Views)
12-17-2012 05:46 PM in reply to: abetts
Tim, indeed, I'm just covering the hopefully obvious.
OP, there is a REALLY annoying problem with the feature Tim spoke of. If your view is not North up could have a situation where no linetypes are upright.
I avoid them and create a copy of the linetype where the text is rotated 180 degrees.
Matt Kolberg
abetts
Message 7 of 11 (383 Views)
12-19-2012 10:35 AM in reply to: abetts
The solution to this ended up being simple. Once selecting the line, in the bottom of the properties box there is an option for "Linetype Generation", it was disabled. Once enabling, all was fixed.
Thank for the suggestion guys!
tcorey
Message 8 of 11 (372 Views)
12-19-2012 02:25 PM in reply to: abetts
Boy do I feel dumb for not getting that one! I knew that contolled where the patterns fall, but I had no idea it would affect the rotation of the lettering. So, in your linetype, you're using U coding for angle, plus Linetype Generation turned on?
Tim
Tim Corey, Owner
Redding, CA
abetts
Message 9 of 11 (324 Views)
01-15-2013 06:07 PM in reply to: tcorey
I'm a girl. :smileyhappy: Aubrey Betts CAD Technician Lennon, Smith, Souleret Engineering, Inc. 846 Fourth Avenue, Coraopolis, PA 15108 (412) 264-4400 Ext. 205 www.lsse.com
abetts
Message 10 of 11 (323 Views)
It seems so. I didn't know this either but whatever works I suppose! Aubrey Betts CAD Technician Lennon, Smith, Souleret Engineering, Inc. 846 Fourth Avenue, Coraopolis, PA 15108 (412) 264-4400 Ext. 205 www.lsse.com
