I have a roadway in cut and I am looking for a way to attach a retaining wall subassembly to the back of my walk so that the wall will retain the slope that we are cutting into. I haven't worked with the wall subassemblies too much, but the insert point of the RetainWallVertical subassembly seem to only be for roadways in fill situations. Since I have limited knowledge on how to manipulate the "out of the box" subassemblies, is there something that I am missing? or can the RetainWallVertical be used for roadways in cut as well?
As an illustration, I have attached a screen shot of what I want the wall to look like.
Any help would be appreciated.
Jamie
Solved by BrianHailey. Go to Solution.
Solved by Jeff_M. Go to Solution.
Retaining wall subassemblies are 'smart', so they can determine when in cut or fill and will change how they are applied accordingly. Here is a pic of a portion of an assembly with the VertWall attached:
And here is that assembly applied to the corridor. The connection for the cut slope is controlled by a surface which was specified to be a certain height above centerline grade for this project.
If you look at the RetainWallVertical subassembly, you'll see that it will work in both cut and fill situations. They have done a really good job with the help system for C3D, especially the subassembly help. Just right click on the subassembly in the tool palette and select Help.
Here is a link to the online help file if you would like to look at it.
