AutoCAD Civil 3D General Discussion
*Expert Elite*
mikeevans
Message 1 of 5 (338 Views)
Accepted Solution
Resource String Error exporting DWFX Civil3d R2014
338 Views, 4 Replies
09-05-2013 03:13 AM
I get a multiple error message dialogue "Cannot find resource string number XXXX in AeccPublishSVC 100 when exporting a DWFX file of drainage in Civil3d R2014 (I have R2013 open as well).
Anyone else getting this?
Mike Evans
Civil3D 2013 / 2014 British UK
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Hi Mike,
This issue might be caused by having pay items assigned. If a pay item is assigned an object that does not meet it's requirements (Unit type etc), it will throw out these errors. Can you do me a favor and unassigned or detach the pay item list, then preform an export to DWFx and see if you still receive the string errors.
Product Support
Jason.Ferrelli
Message 2 of 5 (307 Views)
Re: Resource String Error exporting DWFX Civil3d R2014
09-06-2013 09:00 AM in reply to: mikeevans
Hi Mike,
I have created some pipe networks as well as pressure networks in a C3D 2014 drawing. I then tried to export this drawing to a DWFx while also having C3D 2013 opened. I did not receive any errors.
Would you be willing to upload your drawing(s) so I could test your drawing in my environment?
Jason Ferrelli
Product Support
Jason.Ferrelli
Message 3 of 5 (299 Views)
09-06-2013 10:02 AM in reply to: Jason.Ferrelli
Hi Mike,
Jason Ferrelli
*Expert Elite*
mikeevans
Message 4 of 5 (285 Views)
09-07-2013 09:04 AM in reply to: mikeevans
Will try Monday and let you know.
Mike Evans
*Expert Elite*
mikeevans
Message 5 of 5 (272 Views)
09-09-2013 01:28 AM in reply to: mikeevans
I can confirm that this is due to pay item data being attached, detaching all pay item data from the objects does not produce this issue.
However, I have also tried attaching the pay item data and this also generates the errors. I will look through the information attached to the objects and see if I can find what items are causing the errors.
Mike Evans
Post to the Community
New Post
Need installation help?
