I get a multiple error message dialogue "Cannot find resource string number XXXX in AeccPublishSVC 100 when exporting a DWFX file of drainage in Civil3d R2014 (I have R2013 open as well).
Anyone else getting this?
Solved by Jason.Ferrelli. Go to Solution.
Hi Mike,
This issue might be caused by having pay items assigned. If a pay item is assigned an object that does not meet it's requirements (Unit type etc), it will throw out these errors. Can you do me a favor and unassigned or detach the pay item list, then preform an export to DWFx and see if you still receive the string errors.
I can confirm that this is due to pay item data being attached, detaching all pay item data from the objects does not produce this issue.
However, I have also tried attaching the pay item data and this also generates the errors. I will look through the information attached to the objects and see if I can find what items are causing the errors.
