Civil 3D Forum
Resource String Error exporting DWFX Civil3d R2014
4 REPLIES 4
MikeEvansUK
522 Views, 4 Replies
I get a multiple error message dialogue "Cannot find resource string number XXXX in AeccPublishSVC 100 when exporting a DWFX file of drainage in Civil3d R2014 (I have R2013 open as well).
Anyone else getting this?
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
4 REPLIES 4
Hi Mike,
I have created some pipe networks as well as pressure networks in a C3D 2014 drawing. I then tried to export this drawing to a DWFx while also having C3D 2013 opened. I did not receive any errors.
Would you be willing to upload your drawing(s) so I could test your drawing in my environment?
Jason Ferrelli
Hi Mike,
This issue might be caused by having pay items assigned. If a pay item is assigned an object that does not meet it's requirements (Unit type etc), it will throw out these errors. Can you do me a favor and unassigned or detach the pay item list, then preform an export to DWFx and see if you still receive the string errors.
Jason Ferrelli
MikeEvansUK
in reply to: MikeEvansUK
Will try Monday and let you know.
Mike Evans
MikeEvansUK
I can confirm that this is due to pay item data being attached, detaching all pay item data from the objects does not produce this issue.
However, I have also tried attaching the pay item data and this also generates the errors. I will look through the information attached to the objects and see if I can find what items are causing the errors.
Mike Evans
Rail Community
