Civil 3D Forum
Residential Lot grading
14 REPLIES 14
Message 1 of 15
1780 Views, 14 Replies
Hi all,
I'm looking for ideas on how you would approach this situation that I am in. I'm doing a medium size subdivision (130 lots). I've run my corridor out to the ROW and made a Surface from that. Now I have to do lot grading (yes the engineer wants this - I think its stupid since we're just designing to a maximum footprint and it WILL change when the developer starts placing houses on the lots). But anyways, I have 3 scenarios:
A. Level Land - no basement (Rancher-style house)
B. Walkout with full basement exposed at back of house
C. Walkout with only Basement patio exposed and then shoots back up to grade.
So with those scenarios, here is my workflow:
1. I know what the elevation is at the ROW. From the ROW and center of driveway)I go 5% up to house pad (All driveways are constant 20' long)
2. The Basement level is -7.5' from original elevation.
3. I draw a feature line around the footprint and set elevations.
4. I use FL offset and offset by .01 to show the basement. I set that elevation.
5. I add these FL as Brealines in my surface. It draws the countours.
Only 129 more to go.... It iis my REAL wish that this whole scenario could be tied together with the corridor so that if the road changes, the pads to too. Or if this is too much of a wish then I would like to see a GROUPING of some sortfor the 2 FL's. If the pad elevation changes, the basement will automatically adjust.
I've played with Grading objects a bit and after 4 FE recoveries, I gave up on that! 🙂
Anyone have any other methods, recommendations, etc.?
Rick
14 REPLIES 14
Message 2 of 15
haroldpei1218
It can be tied together if you're using 2009. If not, well...
Message 3 of 15
Many ways to skin a cat...here is a thought:
1) Draw 3D polylines representing your 3 scenarios. Elevations do not matter at this point.
2) Create a feature line of your ROW.
3) Create temporary surface: Stepped offset of ROW feature line 5% for 30'
3) Having never seen your alignments...In some manner draw your twenty foot driveways.
4) Create feature lines from objects (driveways) and assign elevations from your temporary surface
5) move, copy rotate your scenarios to the ends of your driveways (they should pick up elevations from feature lines)
And yes, 09 does make this very easy.
Message 4 of 15
or take scenario driveway and all and snap it to your ROW feature line??
Message 5 of 15
Thanks for the VERY informative response. Yes, I'm sure it can be done in 09 but I haven't wrapped my brain around a good automated process.
Rick
Message 6 of 15
Thanks for the responses. I'll have to give that a try. THANK YOU for your suggestion.
Rick
Message 7 of 15
We build the 3 FL scenarios off to the side of the drawing and make 3 groups. We copy the groups around for each house by a base point off the middle of the driveway connecting to the corridor FLs at that point and editing the two sides of the driveway to tie into the corridor FLs.
I would suggest making sure your cut\fill for the entire site is close to balance using the sub-assembly and steps available under the following AU course (http://au.autodesk.com/sessions/detail/1248/). You need to login with a subscription account to get the goods. Once that is done and cut\fill confirmed to be close move onto the detailed lot grading with the FL groups of the 3 scenarios.
On your next project include those FL groups in a block with the 2D house. As you are placing the 2D house on each lot you can be placing the FLs for the grading (2 in one).
That said, I don't know of any method (even in 2009) that will make your detailed lot grading FLs dynamic with the corridor model. With 2009, I guess you could try doing your detailed lot grading with Grading Objects and it would be dynamic with the corridor but good luck. I don't think Grading Objects will give you the flexibility you need to get the job done for detailed lot grading OR are stable enough to do that kind of detailed warping needed.
mspatz, P.E.
Message 8 of 15
I don't think that you would suggest it if there was any sort of issue. Have you noticed any issues having FLs assigned to a site while nested in a block?
Also, It IS possible for lot grading to be dynamically linked to corridor in 09. It can be accomplished by using the create dynamic feature line from corridor.
Message 9 of 15
FL blocks\groups:
We have not experienced issues yet, but have only used groups with FLs so far in C3D. We have not done the block thing yet. We bring both of these techniques from LDT were we have done both with 3D polylines for years. Worse case, you can just use 3D polylines in C3D as well for the nested blocks if you experience issues with FLs, nested blocks, and Sites in C3D.
Dynamic FLs off the Corridor:
Yes, you can create dynamic FLs off the corridor that follow the point codes but you lose the dynamics when you build off of that FL. It is not like the building footprint will raise and lower holding the driveway FL slope as the corridor moves and goes up \ down. Maybe the next, or next, or next version! 🙂
mspatz, P.E.
Message 10 of 15
haroldpei1218
Actually, it will hold the footprint's elevation when you raise or lower the corridor IF you base the footprint off of the feature line from the corridor. Which would be the whole point of it being dynamic.
Message 11 of 15
?? - what FL command do you use to make this work? OR do you have to have
your sub-assembly from the corridor go up to the front of the house line at
a minimum to have this work?
mspatz, P.E.
Message 12 of 15
haroldpei1218
You just create FLs from the corridor, then select the last box in the Create Feature Line from Corridor window (Create dynamic link to the corridor). Then use that FL to do grading.
Try it, move your alignment around, change your profile, you'll see your grading moves along with it.
Message 13 of 15
yeah, I know that but if you create FLs by slope off of the FLs that are
dynamic to the corridor, the FLs that are created by slope will not move
with the corridor.
In my world this is what is needed to truly make the internal house lot
grading dynamic to the roadway corridor and have the buliding pad move up
and down. That said, I don't see how you would code that to happen (very
complex), so I can't blame the development team.
mspatz, P.E.
Message 14 of 15
I have the same problem, i think if i develop a visual basic (dvb) routine maybe it work or using subassembly to simulate lots
Eng. Herrera
Message 15 of 15
Neilw_05
If you have access to AU Online I highly recommend you view this session. The presenter shows you how to use conditional subassemblies to automaticaly determine where to put walk out pads and other relatively complex lot grading scenarios, all dynamic to the roadway.
http://au.autodesk.com/?nd=class&session_id=5341
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Rail Community
