When using AdMigrator.exe /reset [see here] you can create a ZIP file with a backup of the user settings. Are there any instructions to restore the user settings from the ZIP file?
Allen Jessup
Civil 3D 2012 SP 2.1
Dell Precision T7400, Xeon CPU 3.16 GHz
Win 7 Pro, 64-bit,12 GB RAM, Nvidia Quadro FX 4600
Allen Jessup
CAD Manager - Designer
Solved by AllenJessup. Go to Solution.
I received an answer from Autodesk:
You could use the Admigrator.exe /i in order to import back in the settings.
Allen Jessup
