wang890
Message 1 of 7 (4,185 Views)
reset drawing scale list
4185 Views, 6 Replies
09-18-2012 05:27 PM
before when reset scale it will have 1:1000, 1:2000, something like that.
now when reset it is same as autocad. which is like 1:1 (should be 1000), 1:2 (should be 2000)
what changed? i know it's just the name but this is bad. shoudln't change something like this all the sudden. hopefully is some variable.
working in metric.
Civil 3D 2014
Work: i7 4770, SSD, 16GB, K2000, Dell PH2414H
Home: i7 3930k, SSD, 16GB, GTX 590, U3011
mathewk
Message 2 of 7 (4,172 Views)
Re: reset drawing scale list
09-18-2012 08:44 PM in reply to: wang890
Your default setting have changed. They are set in the registry. You can open the Options dialog and set the default scale list to whatever you need.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Active Contributor
gjcbachman
Message 3 of 7 (4,149 Views)
09-19-2012 07:18 AM in reply to: wang890
What is the command for resetting the drawing scale list?  That will come in handy.
Lisa
Windows 7 x 64
Intel i7-4770 CPu @ 3.40 GHz
24 GB RAM
NVIDIA Quadro K2000D
Civil 3D 2015
Active Member
OsnapBhatch
Message 4 of 7 (4,146 Views)
09-19-2012 07:41 AM in reply to: wang890
the command is "SCALELISTEDIT"  if you use it often like i do, creating an alias such as "SLE" is a good idea:smileyhappy:
______________________________
Tyler H. Johnson
Civil3d 2013
Dell Precision T3500
Intel Xeon
24GB Ram
64Bit Win7 Pro
wang890
Message 5 of 7 (4,136 Views)
09-19-2012 11:26 AM in reply to: wang890
ok cool.
but where in options? i've never see options have a thing for scale list default. i did'nt change anything that's set by civil 3d as default. i guess just don't reset scale then. problem solved.
but still need to find this would be useful . let me know
Civil 3D 2014
Active Contributor
gjcbachman
Message 6 of 7 (4,129 Views)
09-19-2012 12:14 PM in reply to: wang890
User Preferences/Default Scale List (lower right).
Lisa
Windows 7 x 64
24 GB RAM
Civil 3D 2015
AllenJessup
Message 7 of 7 (4,097 Views)
09-21-2012 01:20 PM in reply to: wang890
Once you've got things the way you like them. A good way to make your customized list recoverable is to export the registry section where these values are stored. It will be in a path like
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.2\ACAD-A000:409\Scale List
Export that section to a backup REG file. If things go pear shaped you can run this file and restore the values.
As always - If you're uncomfortable working with the registry. Feel free to ignore this procedure.
Allen
