Civil 3D Forum
reset drawing scale list
9 REPLIES 9
Message 1 of 10
wang890
18186 Views, 9 Replies
before when reset scale it will have 1:1000, 1:2000, something like that.
now when reset it is same as autocad. which is like 1:1 (should be 1000), 1:2 (should be 2000)
what changed? i know it's just the name but this is bad. shoudln't change something like this all the sudden. hopefully is some variable.
working in metric.
Stantec
Dell Precision 5530, Prism M320PU, C3D 14/17/19
9 REPLIES 9
Message 2 of 10
mathewkol
in reply to: wang890
Your default setting have changed. They are set in the registry. You can open the Options dialog and set the default scale list to whatever you need.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 3 of 10
gjcbachman
What is the command for resetting the drawing scale list?  That will come in handy.
Lisa
Windows 10 Pro x 64 bit
Intel Xeon CPU @ 3.8 GHz
32 GB RAM
NVIDIA Quadro P2200
Civil 3D 2020
Message 4 of 10
the command is "SCALELISTEDIT"  if you use it often like i do, creating an alias such as "SLE" is a good ideaSmiley Happy
Message 5 of 10
wang890
ok cool.
but where in options? i've never see options have a thing for scale list default. i did'nt change anything that's set by civil 3d as default. i guess just don't reset scale then. problem solved.
but still need to find this would be useful . let me know
Stantec
Message 6 of 10
gjcbachman
User Preferences/Default Scale List (lower right).
Lisa
32 GB RAM
NVIDIA Quadro P2200
Civil 3D 2020
Message 7 of 10
AllenJessup
Once you've got things the way you like them. A good way to make your customized list recoverable is to export the registry section where these values are stored. It will be in a path like
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.2\ACAD-A000:409\Scale List
Export that section to a backup REG file. If things go pear shaped you can run this file and restore the values.
As always - If you're uncomfortable working with the registry. Feel free to ignore this procedure.
Allen
Allen Jessup
CAD Manager - Designer
Message 8 of 10
jturner
I am not able to change my defaults scale list from Imperial to Metric in ACAD 18 lite. I don't seem to be able to "Apply" the changes for a particular drawing!!!
Message 9 of 10
wfberry
in reply to: jturner
You do know that you are replying to a 5 year old post?
BTW, do not try to change an Imperial drawing to a Metric drawing file.  There are too many problems.
Bill
Message 10 of 10
AllenJessup
Hello @jturner, Welcome to the Autodesk Forums.
I understand why you added your question to this thread. But since this is the Civil 3D forum. Not too many will have experience with AutoCAD LT.  Maybe you would want to ask the question in the AutoCAD LT forum. Or maybe @pendean might have some experience with this.
Allen Jessup
Rail Community
