Civil 3D Forum
Reports Manager - Parcel map Check
4 REPLIES 4
DaveM
1032 Views, 4 Replies
All,
I am trying to figure out how to customize the reports that Civil 3d can generate to my firms needs. I have figured out how to change the appearance and precisions to the most of the numbers, but i still can not figure out a lot. Currently i am working on the output of the Parcel Map Check Report.  If you look at the attachment i have an Image of what i have been asked to generate and an excel file of what i have been able to generate. I need to figure out how to remove the "," from the coordinates and how to rearrange/ change font of the way some things come out. Can you help me with this or point me out to an online article that can.
I am Grateful for any help to the understanding of how this works.
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
ATI FirePro V5700(FireGL)
Win 7 Home Professional
Please use Kudos Where Deserved
4 REPLIES 4
Jeff_M
in reply to: DaveM
The coordinate/distance format and font settings are in the VB.NET code.
In the ParcelFormat.vb file you will find the RoundVal function with this code:
        Dim sFormatString As String
        sFormatString = "N" + prec.ToString()
        RoundVal = roundedValue.ToString(sFormatString)
Change the "N" to "F" to remove the grouping separators (commas).
The fonts are trickier. If you wish to pursue this please repost in the C3D Customization forum and I will dig up some instructions I gave another user a while back.
Jeff_M, also a frequent Swamper
DaveM
in reply to: Jeff_M
Jeff,
This is exactly what i was looking for. I found the folder shown below, but i do not see a file called ParcelFormat.vb. There may be another folder that i am not aware of. I currently do not have any software on my computer that will open the files in the folder. After doing a google search it sounds like i need visual studios, which is very expensive. Do you know of any cheaper software that will alllow me to affect the code, notepad brings in a lot of foreign symbols.
Dave
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
Jeff_M
in reply to: DaveM
Oops, that should have been ReportFormat.vb. The files are in subfolders found at this path: C:\ProgramData\Autodesk\C3D 2013\enu\Data\Reports\Net\Source\
You should be able to open them in Notepad, although I don't recommend it since they still need to be recompiled. Yes, Visual Studio Vb.NET should be used. But there is a free version, get the 2010 Express version here:
http://www.microsoft.com/visualstudio/eng/downloads#d-2010-express
There is a learning curve with this software! I do not suggest jumping right in, thinking you can just make a simple edit and run the report. There are a number of wesites that have some training for this, make sure you go through these first.
blog.civil3dreminders.com <-- you will need to search this site
http://usa.autodesk.com/adsk/servlet/index?id=18162650&siteID=123112
http://adndevblog.typepad.com/autocad/2012/03/page/2/
DaveM
in reply to: Jeff_M
Thank you for the link to that tutorial, I have been looking for something to that degree for a very long time. I have never met someone in person who customizes autocad so it has been difficult to locate what i need to learn to become efficient at it. I hope to one day buy you a beer.
Dave
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
Rail Community
