Hi, I'm using C3D 2013 and I'm trying to create a PVI station report for a profile but all I get is a blank report with just the title. What could be the problem? I tried downloading and using a DLL file posted by Jeff Mishler a while ago but nothing doing.
The funny thing is that another profile from a different alignment within the same project is generating it's PVI report.......I'm just perplexed. Attached is the Land XML version of the alignment and profile.
Please help.......Thanks in advance.
No way, I couldn't have uploaded an existing profile. It's a design profile. Maybe the issue is the profile style, please change it to design or proposed. Am sure I attached a design profile. Thanks.
This is extracted from the XML file you posted:
OK, thanks alot. I've seen it. Why would a design profile behave like an existing ground profile once you export to land XML? The first attachment shows a screen shot of the profile and as you can see it's a design profile. The red one underneath is the existing ground profile. I've also attached a land XML of both profiles now and it's true, the XML data for the design profile is similar to the one for the existing ground, 2D points only. Why would this be the case? Thanks man..
Hey, I found a workaround to it. I copied the PVI data from the panorama to excel then txt and I created the same profile from file. The new profile gave the PVI report without any problems and it's XML is OK too. But am still buffled by how a design profile would appear as an existing ground profile in LandXML. What do you think?
Of course i'd like to share it but it's too large.......unless i remove the corridor and surfaces first or do u know of another place I can share it? Cheers. Btw are you Jeff Mishler....
