Civil 3D Forum
Replace COGO point with surface label
19 REPLIES 19
Message 1 of 20
Joe-Bouza
2030 Views, 19 Replies
Does anyone know of a way this can be done?
Currently I have a grading plan that extracted COGO points from the corridor, which is good to a point (no pun). One must manually update when the corridor surface changes. I also need to reference another surface in the label style, which I can do in the SLS but not the COGO.
Surface label on a grid is not an option because they currently are at station intervals
Joe Bouza
19 REPLIES 19
Message 2 of 20
jmayo-EE
in reply to: Joe-Bouza
One by one unless your programming.
John Mayo
Message 3 of 20
Jeff_M
If you had the Sincpac this could be done by dynamically linking the points to the corridor surface.
Jeff_M, also a frequent Swamper
Message 4 of 20
AllenJessup
in reply to: Jeff_M
And a very tasty way to do it too. Smiley Very Happy I find this to be invaluable when at 8 am I'm requested to modify the grading for something that needs to be staked out that day! It might be easy to modify the grades but not having to then recreate a couple of hundred points based on the new grading is very helpful!
Allen
Allen Jessup
CAD Manager - Designer
Message 5 of 20
Joe-Bouza
in reply to: jmayo-EE
Eeesh!
Joe Bouza
Message 6 of 20
Joe-Bouza
in reply to: Jeff_M
That would be excellent if I could
Joe Bouza
Message 7 of 20
Joe-Bouza
in reply to: AllenJessup
Yummy, and All I get to eat is crow
Joe Bouza
Message 8 of 20
Jeff_M
Joe,
Attached is a zip file with a small .NET dll that will place a SurfaceElevationLabel at the location of selected CogoPoints. It is a quickly written, no frills, command. It does not delete the CogoPoints, it uses the Drawing's defaults for LabelStyle and Layer. All it asks is for the name of the surface to label and to select the cogopoints. VERY basic.
Before extracting the dll, be sure to Unblock the zip file in the file's properties.
Command name is CreateLabelsFromCogoPoints. Should work in C3D 2013 (tested), 2014 (tested) & 2015 (not tested).
Message 9 of 20
Joe-Bouza
in reply to: Jeff_M
You're the best!
Greatly appreciated
Joe Bouza
Message 10 of 20
Neilw_05
Would alignment labels rather than surface labels work for you? Depending on what geometry you are wanting to label you could add a piece of reference text to an alignment label style and apply it to alignments extracted from the corridor.
So for example if you wanted to label the curve PC's and PT's of the edge of pavmement you could create alignments from the corridor EOP and apply the label style which could include references to the baseline stationing & finished surface elev. The labels would be automatic and dynamic.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 11 of 20
Joe-Bouza
in reply to: Neilw_05
I do that for the PGL line, but the grading plan requires sections EOP, MIDLane, CP at 25 foot intervals. that would require a pgl layout profile for each line with a pvi every 25 ft.
good for the pgl but not the rest, but thanks for the input
Joe Bouza
Message 12 of 20
Neilw_05
Perhaps you didn't understand my suggestion. My idea was to extract the EOP from the corridor and make it into an alignment. Then you could set up alignment labels for the EOP alignment that label geometry points and tick intervals just as you do for a centerline. The labels would not show stations but instead would include a piece of reference text that reports the elevation of a surface, in this case the finished surface from the corridor. You would have complete control over which geometry points to label and the incremental intervals (i.e. every 25 ft). The same method could be used to create labels for backs of curbs, etc. It does not require creating profile gradelines since you are extracting the elevations from the surface. (See screen cap)
What I didn't anticipate is the tick interval on the offset alignments do not correspond with the ticks along the baseline of the corridor due to the difference in length along curves. Thus this approach does not give true cross sectional labels, so it is not a solution. Perhaps there is a way to show labels using the corridor sections.
WIN 10 64 PRO
Message 13 of 20
Joe-Bouza
I see what you mean now. I'll check it out tomorrow. thanks
Joe Bouza
Message 14 of 20
Get going on that, Bouza
Message 15 of 20
KirkNoonan
Let me re-phrase to make sure I'm understanding what you are trying to do. You have your COGO points that were extraced from a corridor and you want to update them when the corridor elevations change. You also want to sample a second surface at the same location. As long as it is only the grading that changes and not the geometry, why can't you just put those points all in one group and use the 'elevations from surface' command to get them updated? You could also duplicate those points and with a little label and point style massaging use the same command to display the elevation of the second surface by means of a second point/label at the same location.
Message 16 of 20
Joe-Bouza
in reply to: KirkNoonan
Thats what I ultimately did. I was looking to skip the update step.
Joe Bouza
Message 17 of 20
Joe-Bouza
oh man I had High hopes for that one. The one glitch I cant get around is the incriments, which work excellently but I need them to be at the roadway baseline incriments.I will use on site work though. Good one Neil
Joe Bouza
Message 18 of 20
Neilw_05
The offset tick intervals not matching the baseline is the reason I concluded this was not a solution. I've not investigated the possibility of somehow labeling cross section points in plan view. That would be closer to what we want.
Sorry I misled you.
WIN 10 64 PRO
Message 19 of 20
tcorey
@Joe-Bouza wrote:
You're the best!
I second that opinion.
Jeff , I hope you're in Las Vegas this year so I can buy you a beverage or three.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 20 of 20
Jeff_M
in reply to: tcorey
You bet I will, Tim!
Rail Community
