Civil 3D Forum
replace blocks
12 REPLIES 12
Message 1 of 13
lambertb
1842 Views, 12 Replies
replace blocks
I have a dwt with many styles that have blocks associated. I would like to update these blocks with new ones. The new blocks are all dwg files. Is there a way to import the dwg files and update the block definitions? Will this mess up the styles? Do I need to worry about annotation scales? Thanks.
C3D 2022 and 2024
12 REPLIES 12
Message 2 of 13
mathewkol
in reply to: lambertb
If you insert one of those dwg files and it is the same name as the block, the block will be redefined to match (if you say yes when prompted). Any style using that block will oof course be updated. Annotative scales are ignored by styles.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 3 of 13
lambertb
in reply to: mathewkol
Thanks. Anyway to do this in a batch. I have 100 blocks to replace. Thanks.
C3D 2022 and 2024
Message 4 of 13
Joe-Bouza
Write a script. should take a fraction of the time to insert 100 blocks
Your Name
Your Name
Message 5 of 13
lambertb
in reply to: Joe-Bouza
Having no knowledge of writing scripts, any advice?
C3D 2022 and 2024
Message 6 of 13
Joe-Bouza
A script is merly a text file with keyboard commands and the file has an extension <name>.scr
Practice with the command line >> -insert <block name> yada yada...
There are many utilities available to simplify the process. DOTSOFT.com comes to mind, There may even be a free utility via autodesk.com
Your Name
Your Name
Message 7 of 13
jmayo-EE
You can also drag and drop them from Design Center. Not automatic but you have the option to redefine the block which you do not get dragging and dropping from windows explorer.
John Mayo
Message 8 of 13
lambertb
This methods seem to replace blocks already in a drawing maybe? I have a dwg file with many blocks stored. I have external dwg files that have the elements of a block. When I go to insert block, then browse, I browse to D:\blocks\ac.dwg. etc. Clicking ok asks to redefine the block. Can a script be used to import external files for blocks? The inset command with a file path doesn't seem to redefine the block. It pulls in the block already in the dwg. Thanks. PS I will check for some utilities.
C3D 2022 and 2024
Message 9 of 13
wfberry
I think you would be best served by using Design Center.  (Type DC)  I cannot determine if you have single dwg's for blocks or dwg's with a number of blocks in them.  You know that a single dwg is a block if inserted in your drawing.
Play with Design Center, you will definitey find a need to use it.
Bill
Message 10 of 13
PappaDale
Try Express>Blocks>Replace block with another block (BLOCKREPLACE on the command line).
Message 11 of 13
jmayo-EE
in reply to: PappaDale
BlockReplace does not permit you to update an existing block definition with an external dwg.
John Mayo
Message 12 of 13
Joe-Bouza
in reply to: jmayo-EE
Use Design Center
Your Name
Your Name
Message 13 of 13
kehale
Excellent.  Simple command to 'replace blocks'. Thanks!
Rail Community
