Hi Brian,
I haven't made time to look at a Civil 3D menu yet, but if you examine the
structure of LDD menu commands you can almost certainly repeat that with the
Civil 3D menu instructions.
The lisp to do it may have to be written again, but to a lisp programmer it
should not be difficult.
Laurie Comerford
CADApps
www.cadapps.com.au
"Brian Hailey" wrote in message
news:41c1dbf1$1_2@newsprd01...
> Hi Himanshu,
> I'm aware of those options but, that just does the last command. For
> instance, if I'm editing pipes in LDT and I edit a pipe run graphically,
> exit the command, zoom around to check something out, zoom back, I can
> simply type LDD and it will rerun the last LDT command, i.e. edit pipe run
> graphically. If I hit the space bar, enter, or right click, it will go
back
> to the last command, which in this case, was zoom. As I said, I use this
> ALL the time (well, some other commands as well) and I find it to be a
huge
> time saver.
> Thanks for listening.
> Brian Hailey
> LDT2005
> C3D2005
> XP Pro - SP 2
> P4 2.8GHz
> 1.00 GB of RAM
> "H Gohel" wrote in message news:41c18aeb_3@newsprd01...
> > news:41c0c7af$1_2@newsprd01...
> >> Is there any plan for something that will repeat the last Civil3D
command
> >> similar to LDD in Land Desktop? I use this all the time in LDT and am
> >> finding it a little frustrating not having it in Civil3D.
> > Brian,
> > Try the space bar (as in AutoCAD), or if you prefer the mouse, right
click
> > and select the repeat last command option.
> > Himanshu Gohel. Civil3D Team, Autodesk, Inc.
> > Autodesk Civil3D Product Information <>
