doni49
Message 1 of 3 (110 Views)
Renumber Tags (menu item -- PLURAL). Required to be one at a time?
110 Views, 2 Replies
02-07-2014 09:43 AM
C3D 2012
Select ONE SINGLE tag (Line & Curve label tag).  "Labels - General Segment Label" ribbon tab appears with a menu item "Renumber Tags".
But if I select more than one tag, this item is grayed out/disabled.
1) Is there someway to perform the command on a group of tags?  I removed one tag from the middle and want to decrement the rest of them by number.
2) If you're going to require this be done 1-at-a-time, wouldn't it make sense for this to be called "Renumber Tag"?
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Forum links:
AutoCAD 2013/2014/2015
AutoCAD 2010/2011/2012
AutoLISP, VB and other AutoCAD customization
Civil 3D General
Civil 3d Cusomization
wfberry
Message 2 of 3 (99 Views)
Re: Renumber Tags (menu item -- PLURAL). Required to be one at a time?
02-07-2014 10:06 AM in reply to: doni49
Yes, but if I remember correctly you do not have to start the routine over.
Bill
doni49
Message 3 of 3 (96 Views)
02-07-2014 10:11 AM in reply to: wfberry
It was still a PITA.  I had 50 tags that needed renumbered.  When I saw "Renumber Tags", I thought it would do them all.
Don Ireland
Forum links:
Civil 3D General
