C3D 2012
Select ONE SINGLE tag (Line & Curve label tag). "Labels - General Segment Label" ribbon tab appears with a menu item "Renumber Tags".
But if I select more than one tag, this item is grayed out/disabled.
1) Is there someway to perform the command on a group of tags? I removed one tag from the middle and want to decrement the rest of them by number.
2) If you're going to require this be done 1-at-a-time, wouldn't it make sense for this to be called "Renumber Tag"?
Don Ireland
Engineering Design Technician
It was still a PITA. I had 50 tags that needed renumbered. When I saw "Renumber Tags", I thought it would do them all.
Don Ireland
