Civil 3D Forum
renumber sheets
11 REPLIES 11
Message 1 of 12
nostupidquestions
2940 Views, 11 Replies
renumber sheets
is there a way to renumber sheets in the sheet set manager? i've got over 100 sheets and i need to insert some new sheets in the middle. there wasn't a way in 2009 but i was hoping for something in 2012. it seems like something that would be included by now.
Intel(R) Xeon(R) W-2245 CPU @ 3.90GHz 3.91 GHz
64 GB RAM
C3D 2023.2
11 REPLIES 11
Message 2 of 12
It will not automatically renumber them, but you can go in sheet set manager and change the sheet numbers.
Jonathan Norton
Blog | Linkedin
Message 3 of 12
thanks for the reply. i guess i should have included a 'quickly' or 'automatically' in my post in regards to renumbering. renumbering each sheet takes forever.
64 GB RAM
C3D 2023.2
Message 4 of 12
Nothing built in as you have seen (not sure why after all these years...)
But given enough programming knowledge, it's certainly possible to roll up your own routine.
We have such as tool and it pays for itself every time it is used.
R.K. McSwain     | CADpanacea | on twitter
Message 5 of 12
troma
in reply to: rkmcswain
How does this work if you have sheets numbered:
01
02
03-A
03-B
04
05
Or do you just avoid this type of numbering?
Mark Green
Working on Civil 3D in Canada
Message 6 of 12
i got one somewhere several years ago but it doesn't work with 2012.  i agree that this feature should be included.
64 GB RAM
C3D 2023.2
Message 7 of 12
Jeff_M
in reply to: nostupidquestions
There's also some 3rd party help if it's something you need.
Message 8 of 12
Joe-Bouza
in reply to: troma
Nothing against SincPac, my favorite is SSMproperetieseditor at JTBworl dot com
and it more than renumbering
Your Name
Your Name
Message 9 of 12
rkmcswain
in reply to: troma
01
02
03-A
03-B
04
05
Our numbering is usually very simple (1, 2, 3, 4, etc) - so our routine simply starts with the first sheet (1) and then numbers the rest sequentially. It also updates a custom property with the total number of sheets since we have a field that references that.
Message 10 of 12
marcobee
How can i make sure that my sheets are numbered in a good order considering that am using different files (i have set 5 sheets for each file). The other issue i want to ask is if there there is automatic way of editing datum for profile because i take much time to go through each sheet changing datum
Message 11 of 12
Joe-Bouza
in reply to: marcobee
You have to order the sheets in SSM then sequetially number them
http://www.jtbworld.com/SSMPropEditor.htm
Your Name
Your Name
Message 12 of 12
Joe-Bouza
in reply to: troma
Jimmy's routine handles prefixes and suffixes
Your Name
Your Name
Rail Community
