Distinguished Contributor
nostupidquestions
Message 1 of 9 (718 Views)
renumber sheets
718 Views, 8 Replies
01-02-2013 12:26 PM
is there a way to renumber sheets in the sheet set manager? i've got over 100 sheets and i need to insert some new sheets in the middle. there wasn't a way in 2009 but i was hoping for something in 2012. it seems like something that would be included by now.
Dell Studio XPS 9100
Intel Core i7 CPU 930 @ 2.8GHz
12GB Ram
64 bit
C3D 2015
DSM_dude
Message 2 of 9 (698 Views)
Re: renumber sheets
01-02-2013 01:42 PM in reply to: nostupidquestions
It will not automatically renumber them, but you can go in sheet set manager and change the sheet numbers.
Cad Blog:
http://geauxcad.wordpress.com/
nostupidquestions
Message 3 of 9 (693 Views)
Re: renumber sheets
01-02-2013 01:46 PM in reply to: DSM_dude
thanks for the reply. i guess i should have included a 'quickly' or 'automatically' in my post in regards to renumbering. renumbering each sheet takes forever.
12GB Ram
64 bit
C3D 2015
rkmcswain
Message 4 of 9 (688 Views)
Re: renumber sheets
01-02-2013 02:00 PM in reply to: nostupidquestions
Nothing built in as you have seen (not sure why after all these years...)
But given enough programming knowledge, it's certainly possible to roll up your own routine.
We have such as tool and it pays for itself every time it is used.
troma
Message 5 of 9 (685 Views)
Re: renumber sheets
01-02-2013 02:02 PM in reply to: rkmcswain
How does this work if you have sheets numbered:
01
02
03-A
03-B
04
05
Or do you just avoid this type of numbering?
Credit where credit is due! Give kudos or accept as solution whenever you can.
nostupidquestions
Message 6 of 9 (676 Views)
Re: renumber sheets
01-02-2013 02:17 PM in reply to: rkmcswain
i got one somewhere several years ago but it doesn't work with 2012.  i agree that this feature should be included.
12GB Ram
64 bit
C3D 2015
Jeff_M
Message 7 of 9 (670 Views)
Re: renumber sheets
01-02-2013 02:36 PM in reply to: nostupidquestions
There's also some 3rd party help if it's something you need.
Joe-Bouza
Message 8 of 9 (652 Views)
Re: renumber sheets
01-02-2013 05:02 PM in reply to: troma
Nothing against SincPac, my favorite is SSMproperetieseditor at JTBworl dot com
and it more than renumbering
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
rkmcswain
Message 9 of 9 (638 Views)
Re: renumber sheets
01-03-2013 05:08 AM in reply to: troma
01
02
03-A
03-B
04
05
Our numbering is usually very simple (1, 2, 3, 4, etc) - so our routine simply starts with the first sheet (1) and then numbers the rest sequentially. It also updates a custom property with the total number of sheets since we have a field that references that.
