I have problem with renumbering points in civil 3d. I have points from 3-50, and from 100-150. I want to renumber all points and get points from 1-97. with renumbering i can only get aditive factor, but i cant renumber all points so i have it in oreder from one point to another.
Mirazina,
How about changing the numbers in two steps? Add (-2) to 3-50 and add (-52) to 100-150.
Dave
Dave Stoll
Las Vegas, Nevada
Its ok idea, but it is pain in **** when you are surveyor, and you have 3 teams surveying, first team uses numbers from 100-200, but misses numbers, 124,126,128....second team uses numbers from 300-400 but misses numbers 226-240, and third team uses numbers from 300-400 but misses numbers 307,308,309,311,313.
And now i want it renumber all from 1 - xxx, so i can have it in order...
Mirazina,
I don't know a way to do a batch renumber, but I'll bet someone else here knows a way.
Dave
Dave Stoll
Las Vegas, Nevada
AFAIK It's not possible without programing. We leave field shots as they are to match the field books in case there is a question later on on elevation or description.
Allen
Allen Jessup
Engineering Specialist / CAD Manager
Allen
Same here. I can't even begin to imagine the headaches involved with doing otherwise. I think it would be better to have the field crew use the proper numbers in the first place.
Don Ireland
Engineering Design Technician
Probably the quickest way would be to export the points to a CSV file, open it in Excel, erase the points, start with 1 and fill down to create consecutive numbers, delete the points in the file and import the edited CSV file.
Allen
Allen Jessup
